Old 01-26-2009, 04:10 PM   #1
genethekiller
Drives: 2008 Yaris Liftback
Oil 5000 miles +
I have a great mechanic here in Germany, good honest guy always looking for ways to save me money, (a la buying oil from US shops, 5w-30 is ridiculously expensive in Europe)
But every time I take my car to him for an oil change, he tells me I don't need to bring it in that often. It's been nearly 5000 miles, I always change early, just a couple hundred miles or so, but I don't think he gets it.
It's a common sense issue I know. I'll do what I know is right regardless, but my question is, has anyone here heard of going longer than 5000 as a regular thing? I've always felt (and it's common knowledge) that oil is the lifeblood of the engine, and if anything, should be taken care of early and often.
I'm assuming that it's an issue of kilometers vs. miles. But I was just curious.
genethekiller is offline   Reply With Quote
Old 01-26-2009, 04:17 PM   #2
Yawesh
Yawesh's Avatar
Drives: 08 sedan at
i personally think 5000 is the Max, waiting over that to change oil- even synthetic would be nuts
regular oil in my opinion should def be changed at 3000 miles
synthetic oil in my opinion can be held to 5000 miles
Yawesh is offline   Reply With Quote
Old 01-26-2009, 05:23 PM   #3
nemelek
DWEED
nemelek's Avatar
For warrantee purposes alone I stick with Toyota guidelines. The benefits of timely oil changes pay off after 100,000 miles. If you plan on keeping the car for 3 years let some oil changes slide. If you plan on keeping the car 10 years keep on top of the oil changes. Different manufactures have different guidelines. My wife’s CR-V has a % oil life left number on the readouts. It’s gone 3000 miles and had 60% left. Using those guideline the first oil change will happen at 7,500 miles. The Honda owners manual says to change at a year if the % life isn’t used up. Toyota recommends to change in 5 months if the 5,000 mile mark isn’t reached. My Dodge diesel truck has 7,500 mile oil change intervals for heavy use and 15,000 miles light duty use. However the diesel takes 12 quarts to change.
I had an old girlfriend that drove 80,000 miles with no oil changes before the car froze up.
Old 01-26-2009, 06:01 PM   #4
tetzyamis
'09 5dr
tetzyamis's Avatar
Drives: 2009 Yaris 5-Door Bayou Blue
Wow. Was the reason why the car froze up because of the oil? Or was it caused by something else?
2009 5-Door Yaris LB Bayou Blue Pearl
2009 5-Door Yaris LB Black Sand Pearl
tetzyamis is offline   Reply With Quote
Old 01-26-2009, 07:08 PM   #5
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
You have a good mechanic. Germans "get it". While Americans are still clinging to the "change your oil every 3,000 miles" that the oil companies have been feeding us for many, many decades and are hesitant to even go to 5k, the German car makers are going 10, 12, even 15k miles between oil changes.
Doing what is required to maintain your warranty is good, but once your warranty is up, recognize that even 5,000 miles is very conservative with a modern engine using modern oils. Even with conventional oil, I wouldn't hesitate to go to 7 or 8k, maybe even 10k. With good synthetic oil, 15k without question.
My Yaris warranty isn't anywhere near expired, and I've already decided that I'm going with a 15k interval. I'm about half way through it right now and my Mobil 1 looks just like it did when I poured it in. I figure if it's good enough to be the factory interval for the Brazilian-made engine in my wife's MINI Cooper, it's good enough for my Toyota.
Old 02-12-2009, 03:22 AM   #6
dallas
Drives: Yaris Hatch /Landrover D2
Good info, some Euro mfg go as long as 40,000 km to an oil change. in North America the BMW LL4 spec is over 20,000 km change, but you have to use a ACEA (euro) oil to meet the standard. THe VW TDi diesel is hard on Oil and the drain is 15,000 km, Better base oils and additives allow the longer drain intervals. The problem is that Canadian and US gas contains Methanol/ethanol which is hard on the oil. I go 12,000 Km with Euro oil with no problems, but would recommend following Toyotas suggestions if you want warrantee.
dallas is offline   Reply With Quote
Old 02-12-2009, 12:00 PM   #7
phenoyz
phenoyz's Avatar
Drives: yaris
can you use bmw genuine synthetic oil 5w-30?
phenoyz is offline   Reply With Quote
Old 02-13-2009, 11:16 AM   #8
TheSilkySmooth
TheSilkySmooth's Avatar
Who knows what this stuff is? I thought they use Euro Castrol BMW spec 15W-60? Motul Or Elf extended drain LL A3/B3 5W-40 rating tends to be the best, lowest wear, longest life. Easy 8000 mi OCI intervals for the Yar if not a short distance driver in Manitoba.
Old 01-26-2009, 07:29 PM   #9
ddongbap
I'm rocking 9k miles on my conventional.
Old 01-26-2009, 07:35 PM   #10
MadMax
MadMax's Avatar
By the way, this guy isn't in Ramstein village, is he? Last name Kaprowski?
I used to have a great BMW mechanic that worked on my two E30 3-series and I swear I have never had such an excellent mechanic! I wish I could get him over to Texas.
But Loren is exactly right, with today's modern blends the days of 3-5000 mile oil changes are becoming a thing of the past. If you are really concerned about breakdown, send a sample to a laboratory after you do your next oil change and you will be surprised how little it has deteriorated!
Cheers! M2
Old 02-01-2009, 12:48 PM   #11
genethekiller
Cheers! M2
No, his name is Edwin Lugo. Awesome guy, always makes sure your stuff is good to go. I love German mechanics. And he's the best.
Anyway, this guy's shop is in Landstuhl.
Old 02-01-2009, 01:30 PM   #12
Kal-El
Kal-El's Avatar
Going 15,000 miles between changes means you don't care about your car.
Toyota engineers (those silly guys that built the engines ) say 5,000 miles. That's what I follow.
I'd say 7,500 should be the limit.
Old 02-01-2009, 06:31 PM   #13
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
I agree, but that's the US oil change interval... I find it very interesting that the European Yari have longer intervals, like Andies 9,000 mile (15,000 Km) recommended change from post #18. His TS has the same motor as the new Corolla, so whats the difference?
You have to question why US yari have shorter recommended oil changes compared to the rest of the world.
Old 02-02-2009, 07:46 AM   #14
Kal-El
Kal-El's Avatar
Yes, I'm quite curious to know why the intervals are different.
Old 01-26-2009, 08:19 PM   #15
Chupacabra
Drives: 2009 Yaris liftback
cheapest insurance you can buy....change your oil as often as possible.
Chupacabra is offline   Reply With Quote
Old 01-27-2009, 08:19 AM   #16
voodoo22
Drives: Yaris Sedan (auto)
Very wasteful.
voodoo22 is offline   Reply With Quote
Old 01-27-2009, 12:19 PM   #17
TheSilkySmooth
+1 and use gray-market imported european REAL synthetics - these hot running, high technology motors will not last on conventional oil.
Old 02-13-2009, 02:19 PM   #18
SilverGlow
Drives: 2007 Yaris Hatchback
Sure, for those that ignore science, common sense, are easily dilluted, cheated, and have no use for research, Used Oil Analysis (UOA's), and have no sense of financial success, go right ahead.
SilverGlow is offline   Reply With Quote
DIY: CHANGE MANUAL TRANNY OIL ttufrosty DIY / Maintenance / Service 157 09-07-2018 02:43 PM
Engine oil ddi not come out hans_fh DIY / Maintenance / Service 18 01-24-2009 12:30 AM
oil and oil filter question.. marcus DIY / Maintenance / Service 27 07-11-2007 04:25 PM
metal particles in oil 007 hatch DIY / Maintenance / Service 9 06-22-2007 03:56 AM
