Old 09-22-2007, 07:25 PM   #1
KSIbucky
KSIbucky's Avatar
Drives: 2007 Yaris manual dark silver
Send a message via AIM to KSIbucky Send a message via MSN to KSIbucky
Yaris speed turns
I'm wondering whats the fastest you've gone in a sharp turn(what angle have you) someone told me that a mini cooper can go 45mph on a sharp turn (which i think is bs but...) I think i've gon 30mph but i have a stock suspention
(your definition of a sharp turn)
7 Color Tach
Fujita Intake
Momo pedals Shift knob and boot. Full TRD SSK.
Blitz exhaust
Megan Lowering Springs
(Next is DC Header)
KSIbucky is offline   Reply With Quote
Old 09-22-2007, 08:00 PM   #2
sf180th
Back in USA in days!
sf180th's Avatar
Drives: 07 Yaris S Sedan
Send a message via Yahoo to sf180th
I've taken a 90 deg turn doign 20 to 25 in the town I live in, I'm sure I would have spun out have I not had the tires and suspension drop I have
Kazera KZ-V Silver Rims, with 215-35-18 Kumho ESCTA ASX, TRD Springs, TRD Sway Bar, Fujita CAI, Blitz R-Vit i-Color, Blitz Throttle Controller, Megan Header, 2.25 Stainless Cat back Exhuast, 50 Series Flowmaster muffler, 6000k HID.
sf180th is offline   Reply With Quote
Old 09-22-2007, 08:57 PM   #3
KSIbucky
KSIbucky's Avatar
i think you can go faster
7 Color Tach
Fujita Intake
Blitz exhaust
(Next is DC Header)
Old 09-22-2007, 09:16 PM   #4
jdium
Mr Attitude
jdium's Avatar
Drives: Blazing Blue 5 Spd
Ask Jerkratt
It's scary to think that half the people surrounding you are below average...
jdium is offline   Reply With Quote
Old 09-22-2007, 11:57 PM   #5
Lafiro
Drives: 06 Yaris Sedan
Tires/suspension, I have done the 90degree turn in about the 20-30mph range. Any faster you will lose all traction and crash.
Old 09-23-2007, 03:19 AM   #6
yrsdrgn
yrsdrgn's Avatar
Drives: 2007 Yaris
i've gone 40 in a 90 degree turn after my car was dropped and on stock tires
Old 09-23-2007, 03:57 AM   #7
dngz
dngz's Avatar
Drives: black yaris sedan
i've gone a pretty tight curve, probably like 100ft curve which almost goes almost 140 degrees, around 100km/h with megan coilovers and sticky tires.
dngz is offline   Reply With Quote
Old 09-25-2007, 04:36 AM   #8
drecian
drecian's Avatar
Drives: '07 YR 3dr
Depends on how tight the turn is and how you drive. On hairpins, the fastest I can usually get around them is aounrd 40mph/60kph exit speeds, of course lower if the radius is smaller. On 90*/rightangled corners, gripping; I can usually hit them at 45mph/70kph before I understeer wide. HOWEVER, if you throw the car into a slide so that you have completed *most* of the rotation for the corner by the apex, you will less understeer-related problems. With this method, exit speeds ride to about 50mph/80kph. Note that is is not drift with crazy slip angles, and if you are using little/any opposite lock countersteer, you are loosing speed as your are trying to 'recover' the slide. Think more rally technique rather than drift. Those who have driven/played on dirt know that to drive a car fast in low traction situations require a different technique to overcome understeer, usually by rotating the car before the apex to reduce the steering input on exit and allowing to power out without running excessively wide. Well; once you reach the grip threshold of your tires, it becomes a low traction situation, just like drivingon dirt, but at much higher speeds...
Remember, the track's the only safe place to experiment...
"I drive a silver egg"
"Huh?"
"An egg... You know; pretty much round, but with a pointy end; jeez..."
drecian is offline   Reply With Quote
What is the most economic speed for Yaris? hans_fh General Yaris / Vitz Discussion 18 02-18-2007 05:34 AM
New Yaris Owner Kiteless General Yaris / Vitz Discussion 8 08-03-2006 12:48 AM
