Old 06-19-2007, 02:28 PM   #1
joey1320
joey1320's Avatar
Drives: Yaris LB
got the turbo PICS NOW>
ok i'm just gonna start over since some of the info from earlier was wrong.
ok, i have 2 used turbos to use on my '07 LB, one is a '99 VW Jetta K03 turbo, wastegated internally at 5psi.
the second is a Garrett GT2056 wastegated internally at 7psi. both are used as stated above, the k03 has 80k miles on it so a rebuild will be necessary if i decide to use it. the gt2056 has 4k miles of use and is in perfect condition, therefor i'm going to be using the Garrett turbo for my setup. just gotta keep putting the pieces together, but first i need to get a spare engine.
Heres a couple of pics of the turbos so you guys can see the difference between the 2.
heres the info from Garrett, regarding the GT2056.
GT2056
these are pics of the K03.
joey1320 is offline   Reply With Quote
Old 06-19-2007, 02:41 PM   #2
Doc Zaius
Lurker supreme!
Doc Zaius's Avatar
Drives: old and boosted!
First off, I'm a turbo n00b... I only know what I've read and researched online. That being said, I have a feeling the GT25 will be too big. I've been looking into either a GT20 or GT17-sized turbo for the Yaris. Since our engines are only 1.5L, and redline @ 6,300-6,500 RPM, they can't flow too much air. The length of time needed to spool a GT25 up would mean it wouldn't be very streetable... i.e. slow response. Also, I think with this size of compressor, you'd possibly be operating near surge at lower RPM.
Anyhow... I don't know about the K03. I'll have to read about that. But ya, if you can find the compression map or specs for either or both of the turbos, some of the more experienced members here would be able to give you some solid advice!
2006 Red Blitzed RS 5-door
Old 06-19-2007, 02:58 PM   #3
NonStopTuning
Sounds like an interesting project Joey. Might I suggest looking for a Toyota CT9 or CT12 turbo. I have had personal experience with these on a 1.5 Toyota in the past and the response was excellent. The turbos are also very small and very easy to fit into the engine bay. Just a thought.
MIKE @ NST
www.NonStopTuning.com
Old 06-19-2007, 03:37 PM   #4
sdmf
Down With the Sickness
sdmf's Avatar
Drives: 2007 yaris liftback
Send a message via AIM to sdmf
would there be another option for turbo in the future?
Strength - Determination - Merciless - Forever
sdmf is offline   Reply With Quote
Old 06-19-2007, 04:47 PM   #5
joey1320
joey1320's Avatar
Drives: Yaris LB
i have been thinking about all kinds of turbo sizes and ideas as to what use, but these two turbos are free and the Garrett is in perfect condition. so i'm gonna go with it, if it doesn't work goo dthen i'll use the k03 since its a perfect replacement.
thanks for info!
Old 06-19-2007, 09:15 PM   #6
weaponrcamry
Drives: Camry LE/Yaris Hatch 5spd
I guess your looking for a complete build. For me if I decide to boost my motor I would use the ct26 or ct27 that were used in the older supras, mr2, or celica all trac. Good for about 16lbs of boost. Spikes around 18lbs or so. But I guess you found the turbos you wanted, which is a good thing... How much boost are u looking for?? Good luck with your project...
|.....Overnight.........................| ||
|........Parts From Japan.............||'|";,__
|_..._...____________======||_|_|....,,]
weaponrcamry is offline   Reply With Quote
Old 06-19-2007, 09:23 PM   #7
Black Yaris
der Zeck
Black Yaris's Avatar
Joey, couldn't you just ebay your Garrett Turbo , for one of the Toyota turbo's NST has used on 1.5's b4 with positive results? just a though
Old 06-19-2007, 09:49 PM   #8
joey1320
joey1320's Avatar
Drives: Yaris LB
i could but if you look at the Garrett webpage they consider the GT2056 appropiate for engines with 1.4L-2.0L of displacement. The good thing is that if i use the Garrett and for whatever the reason i don't like the way it spools or reacts to the build i can replace it with the smaller K03 which is a straight swap for the manifold.
so in other words i can have 2 turbos for the same manifold with difference results. both were free and all i'll have to do is get the rebuild kit for the k03 which is about $65 from ebay.
what do you think?
Old 06-19-2007, 10:19 PM   #9
Turbo&Auto
Turbo&Auto's Avatar
Drives: 07
Forget the K03, it will net small gains. Too much fab and tuning for a lil gain when you have a better candidate waiting :)
A GT25 would be nice, or even the GT28R :D
Turbo&Auto is offline   Reply With Quote
Old 06-20-2007, 12:01 AM   #10
WRBlue
Drives: Yaris 3 Door, 04 WRX, 69 Lotus
IMHO, even the GT2056 is too small.
I assume your gonna build the engine, so I figure 1 bar of boost, with a 1psi pressure drop. So thats a PR of 2.07 and a corrected mass flow of 20.13. That drops you out of the maximum efficiency. Running a GT2252 however would be perfect, that drops you right in the maximum efficiency island. On a Yaris, to run a GT2056, you want to run ~9psi. Any lower than that and you rapidly drop off into crappy efficiency.
WRBlue is offline   Reply With Quote
Old 06-20-2007, 12:31 AM   #11
Black Yaris
der Zeck
Yeah... so I do not know anything about boost.... so I am going to shut up now
Old 06-20-2007, 12:42 AM   #12
joey1320
joey1320's Avatar
Drives: Yaris LB
hey we are all learning here...
my plan is to get 150 whp which i think will make for a great daily driver. yes i can push it past 200whp and what not but i want a reliable car. one that once is put together i'll only have to do the regular oil changes and maintenance.
so with the GT2056 being internally wastegated at 7psi, you think is not gonna be an efficient turbo?
the engine is gonna get a simple build. rods, pistons, new headbolts(hopefully arp) and emanage. the bore will be the same 75mm and the compression rario should be at 9.5:1. i plan on getting a different intake manifold and may a tC TB like "turboyaris" has. but thats all. the head/drivetrain will be stock.
Old 06-20-2007, 12:45 AM   #13
Black Yaris
der Zeck
So.... Joey, You build a turbo setup that is a clean install, I will so drive my happy lil ass out there to run the same set up for what for what ever fair price you come up with
Old 06-20-2007, 12:46 AM   #14
Black Yaris
der Zeck
I am sure there is another Ohio boy that may be interested in this as well
Old 06-20-2007, 12:52 AM   #15
joey1320
joey1320's Avatar
Drives: Yaris LB
thats the plan. a simple, clean, reliable turbo engine.
not 30939484995 horsepowers to the wheels on a front wheel drive.
what for???
thats what happened to my friend who i got these turbos from. he has a '99 Jetta and wanted BOOOOSSSSSTTTT. so after replacing the stock turbo(k03) with the Garrett he was still not happy. Even tough he was boosting 19psi. so he got a humongous Garrett turbo with 27psi of boost.
he build the engine, spending almost $8grand on it. took it to the dyno, made 461whp, drove the car less than 2 weeks and one of the intake valves exploded. so now he needs a new engine, turbo and all the miscellanious stuff...
why do peoplw do that, i don't know. i guess ego...
Old 06-20-2007, 03:27 AM   #16
external wastegate would be more controllable, just a thought
Old 06-20-2007, 09:59 AM   #17
YarisTom73
46 and 2, just ahead...
YarisTom73's Avatar
Drives: 07 Yaris sedan
Once one of you guys get a setup like this up and running, Ohio is just a short day drive for me, I'd love to see it/replicate it. Keep us posted please...
YarisTom73 is offline   Reply With Quote
Old 06-20-2007, 10:41 AM   #18
Doc Zaius
Lurker supreme!
Doc Zaius's Avatar
Alright... here's my thoughts:
This is the compression map for a GT2056, 55 trim... probably the same or close to what you have. Now, if you're hoping to make 150 HP at the crank, and we assume a few things like air/fuel ratio of 12:1, and fuel consumption (BSFC) of 0.6, then your actual airflow will be about 18 lb/min. Depending on the actual air/fuel ratio or fuel consumption, this could actually be anywhere from about 16 lb/min to 20 lb/min.
Next, to figure out the Manifold Absolute Pressure, we take the airflow value of 18 lb/min, and a few other things:
  • gas constant = 639.6
  • intake manifold temp = 130 F (assumed)
  • volumetric efficiency = 96% (assumed)
  • engine speed = 6,400 RPM
  • engine displacement = 1,500cc
Plug all that into a equation, and get a MAP of about 24, but could be anywhere from 21.5 to 26.6 or so. Subtract ambient air pressure (14.7 psi), and add a few psi for pressure loss due to piping and air filter restrictions, and you're looking at a pressure ratio of about 1.9 (could be 1.7 to about 2.1).
Whew!
Plotting 18 lb/min and 1.9 pressure ratio on the graph, and you're looking pretty good. Pretty far from the choke line on the right... and just off the biggest efficiency island at full RPM. If we replug in some numbers to find out airflow @ 3,000 RPM with the pressure ratio of 1.9, we get 8.5 lb/min, so just barely inside the surge line on the left.
So these are just the numbers... interpreting them is not my thing. It looks like this turbo would be good for high RPM operation, but might have a bit of lag. I don't know. But good luck... I'll be following this project with much anticipation!!
BTW, all these equations and stuff I learnt came from Garrett's website, and building an Excel spreadsheet to help play around with values.
TURBO DIY... forpinks Forced Induction Forum 33 09-06-2007 03:03 AM
Toyota Vios Turbo elsteverino889 Forced Induction Forum 4 05-03-2007 12:54 PM
ZPI to produce yaris turbo kit and exhaust turboyaris Forced Induction Forum 30 04-04-2007 03:10 PM
NCP 91 RS 1500 TRD Turbo ????? ramishrrr General Yaris / Vitz Discussion 3 01-15-2007 05:51 PM
Vitz Rs turbo vs U.S. Yaris add turbo? weaponrcamry Performance Modifications 18 08-09-2006 09:45 PM
