OIL CATCH TANK increase performance?
will the oil catch tank increase the car performance??
No.
+1 there designed to catch oil before it gets to the intake pipe
08 junction produce belta almost done and ready for paint 06 junction produce tc 604 bhp 445tq ddriven still trying for 700+hp 90 crx sir ls vtec turbo 755 hp mecp masters certified |
Touge Driver
so what does it do?
Any benefits or harm if installed? |
Who said Yaris was slow?
Prevents oil to enter the intake manifold.
This condition over a long period of time has ben known to cause sludge formations and leading to other problems on some other Toyota models. I have never heard of this problem on the Yaris tough. To your question: It won't harm you to install one. Is it really need it? Probably not. Does it look cool on your engine bay? Yes |
its used on boosted cars. on na cars it wouldnt make any sense to install one not unless you add one and add a filter to the inlet side thats the side that comes from the manifold to valve cover i ran one on my tc then i boosted it so now it beneficial to me
hmm, I don't have one on any of my three boosted cars...
try running a clear hose and watch how fast it will build up with oil
ive ran without it before its just an extra security to keepin the valves clean
Break'em off some.
Not really needed on a yaris.
nope cause oil is only sprayed out as the pressure increases in the valve cover if the pressure doesnt then nothing. which in boosted cars it does. nas only if you disconnect the hose from the manifold to the valve cover and out a filter on the inlet side there is now an unequal amount of pressure difference created instead of the natural push and pull effect
#12 | |
With a proper catch can setup, the crank case vent is still connected to the air filter box, then you replace the PCV valve on the head with a simple nipple connected to your catch van via a hose. The PCV valve should be moved to the outlet of the catch can to prevent pressurizing the catch can when under boost. From the catch can a hose goes to the intake manifold like normal.
Since most PCV valves leak on turbo cars we end up with a slight positive pressure in the crank case under boost and this back flows out the vent connection into the air inlet hose leading to the turbo crapping it up with oil, water vapor, and blowby gases. . this is what a catch can does
#14 | |
lol thanks i had to type it on the side before my uncle gets pissed cause im not doing any productive work when i should really be doing some parts orders for his body shop
Bathroom + Laptop = <3
cars have ran 100k+++ miles without them, why rice a system that is stable? just do oil changes on time with proper synthetic...
Ecurie Snoopy Lives
The puke can can be useful on an engine with mods, but our cars stock run lean.
I did notice gunk coming out and if you run the car hot enough to burn off the gunk at intake. You should be ok. The stock Yaris driven under normal conditions are ok without it. I only havevto clean out my can every 6 months.
Sponsors and Organizations: Toyota Rally Canada Yokohama Tire Canada Western Canada Rally Association Ecurie (Team) Snoopy Canada, racing since 1966 ![]() |
Parallel Parking Pro
If you had a stock AFR chart you'll see that the car runs roughly stoichometric till about 4000+ rpms when it goes very rich.
Leong's NCP91 Toyota Yaris E Hankook V12 Evo 195/55/15 on Buddy Club P1 replicas 15x7 ET +38 Stebel horns, Philips Silvervision turn indicator bulbs TTE Lowering Springs, Camber bolts TRD Blue brake pads Fujitsubo Super Wagolis axleback exhaust DC Sports header |
| The Yaris Performance Primer | eTiMaGo | Performance Modifications | 31 | 10-20-2025 09:08 AM |
| DIY: CHANGE MANUAL TRANNY OIL | ttufrosty | DIY / Maintenance / Service | 157 | 09-07-2018 01:43 PM |
| $30 Oil Catch Can, DIY | Ogredude | DIY / Maintenance / Service | 79 | 05-13-2011 11:05 AM |
| Compiled 1NZFE Used Oil Analysis | craigq | DIY / Maintenance / Service | 7 | 09-10-2007 04:27 PM |
