Old 03-31-2009, 10:02 AM   #1
stripey
Pretty green Yaris Verso
stripey's Avatar
Drives: Toyota Yaris Verso
Fuel economy readout is false!
Anybody else find that on their Yaris the fuel econony, although good, is nothing like as good as the the in-car visual display claims it is?
I regularly get 44 - 46 miles per gallon out of my Yaris Verso, but when I do, the little screen claims that we're getting 60 - 64. I reset it every time I fill up and always fill the tank right up, so what's going on here?
Is it boosted high just to sell the cars in the first place, I wonder?
stripey is offline   Reply With Quote
Old 03-31-2009, 10:55 AM   #2
roxy1
Drives: 2014 yaris 5 speed
i'd say it is safe to say most of us here dont have that problem
...............since we dont get the mileage display
roxy1 is offline   Reply With Quote
Old 03-31-2009, 11:03 AM   #3
BailOut
Steals terrorist's lunch
BailOut's Avatar
Hi Stripey,
As was mentioned the NA Yaris does not get the MPG display. Only the hybrids get it.
The hybrid's display tends to consistently read 5-10% high but what you are reporting is way off of that. Could it be the difference between Imperial gallons and US gallons at play? If not you should visit a dealership to have it calibrated or replaced.
- Brian
Share the Road
Old 03-31-2009, 02:36 PM   #4
stripey
stripey's Avatar
All the Yarises in the UK have it, and the difference is more than that between US and Imperial gallons. I'll mention it at the next service, but as I've learnt simply to read 75% of what it says, I'll let it be unless they'll do it free!
And although I bought this car in Denmark, it is supposedly UK spec, although the chaps in Japan may have got confused over units!
Last edited by stripey; 04-01-2009 at 05:00 PM. Reason: Another thought came to me!
Old 03-31-2009, 03:54 PM   #5
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
i say post a formula for calculation. other member uses different formula on this.. i still dont get people getting over 840km on a 36liters of gas??? even me driving 90km/hr all the way i dont think ill hit that..
Old 03-31-2009, 04:43 PM   #6
YarisSedan
Drives: 08 Yaris Sedan
So you actually have a display that shows your MPG on your dash? Why dont we have those! Atleast you have one!
Old 03-31-2009, 05:58 PM   #7
m911gt
Carless in Chicago
m911gt's Avatar
Drives: 08 Blk LB
If he is talking about the displayed estimated MPG, the problem could be the measuring apparatus of the tank. If the measuring mechanism is fairly cheap, it consists of a vertical bar that takes measurements in the vertical direction and converts the vertical displacement of fluid into a digital signal and displays the value on the dash. The problem with this type of measuring system is that the measurement is taking into account vertical displacement only, when it should be measuring a volumetric change, hence the estimated amount of fuel left in the tank is an incorrectly high value. The correct type of measuring system (measures volumetric change) is a four-bar mechanism which has a pivot that allows a more accurate measurement to be taken.
If this isn't what you're talking about, I apologize...that's all I know about the potential issue. Also, if anyone needs to make a correction to my explanation, please do.
Wanted: Forced Induction
Old 04-01-2009, 01:15 PM   #8
stripey
stripey's Avatar
Mine are imperial gallons, so 45 mpg comes out as 15.86 km per litre
(Divide by 4.54 then multiply by 1.6)
which comes to 571 km for 36 litres.
Old 04-01-2009, 01:17 PM   #9
stripey
stripey's Avatar
[QUOTE=m911gt;278488]If he is talking about the displayed estimated MPG, the problem could be the measuring apparatus of the tank. If the measuring mechanism is fairly cheap, it consists of a vertical bar that takes measurements in the vertical direction and converts the vertical displacement of fluid into a digital signal and displays the value on the dash. The problem with this type of measuring system is that the measurement is taking into account vertical displacement only, when it should be measuring a volumetric change, hence the estimated amount of fuel left in the tank is an incorrectly high value. The correct type of measuring system (measures volumetric change) is a four-bar mechanism which has a pivot that allows a more accurate measurement to be taken.
Could well be this, but then I would expect some other Yaris owners o recognize the problem. I suspect you're right, as my fuel gauge is very susceptible to the car being left on a slope.
Old 04-01-2009, 02:10 PM   #10
marcus
toyota
marcus's Avatar
now if this calculation is right then im getting 45mpg im doing about close to thesame 570-585 on a 36 liters..{7 bars}
but based on other calculation im doing about 38mpg.
Old 04-01-2009, 04:58 PM   #11
stripey
stripey's Avatar
38 miles per US gallon?
That's about the same as 45 per Imperial (English) gallon
Fuel Efficiency and the Yaris BailOut Fuel Economy Forum 326 02-15-2025 11:09 PM
Yaris Fuel Pump HTM Yaris General Yaris / Vitz Discussion 12 03-22-2012 04:34 AM
Are you happy with your Yaris's fuel economy? dinamix General Yaris / Vitz Discussion 41 01-25-2009 09:29 PM
Yahoo Autos! article bobselectric General Yaris / Vitz Discussion 8 01-06-2009 09:27 AM
The Advantages of Nitrous on an Engine KCALB SIRAY Performance Modifications 7 01-02-2009 11:53 AM
