Old 04-09-2009, 11:15 PM   #1
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
My trip to the machine shop
Went to the machine shop today after picking up some misc. hardware and at the end of the day we spat these out. Adjustable swaybar endlinks! I know there is a GB for these now but with my companys accounts with machien shops, applied industrial technologies, and bolt and screw places i spat these out for a clean $100. made from aircraft grade aluminum and stainless heim joints ( i forgot the rating number but they are the same grade used in landing gears, old ones are in the picture on the rods, new ones will be in tomorrow) All highest grade hardware as well. sometimes i do like going to work!
Old 04-09-2009, 11:17 PM   #2
Saggio
Top Notch!
Saggio's Avatar
Drives: 2008
Coooooooooooooooooooooooooooooooooooooool
Blah, Blah, Blah, Blah
Saggio is offline   Reply With Quote
Old 04-09-2009, 11:18 PM   #3
mikenacarato
SIPNDEW
Drives: 15 STI
i cant wait to test drive them once i get the new heim joints in. im super excited!
Old 04-09-2009, 11:32 PM   #4
YarisSedan
Drives: 08 Yaris Sedan
Damn i like the look of these better. The only comment is since it dosnt have a hex pattern it would be hard to rotate them without using pliers or something that would scratch the surface. Instead of using a wrench. But to me i like the look of these better.
Old 04-09-2009, 11:36 PM   #5
mikenacarato
SIPNDEW
Drives: 15 STI
hehe thanks. the aluminum only costed me $5 using my companys discount
Old 04-09-2009, 11:48 PM   #6
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
hello :) looks very nice. May I ask what kind of aluminum? 6061? 0, T4, T6?
Yeah, maybe you should have the machinist mill some flats at the rod ends so a wrench has a place to hold.
Old 04-10-2009, 01:04 AM   #7
mikenacarato
SIPNDEW
Drives: 15 STI
ya ive thought about doing that on my next set. these are just a prototype set. the rod is made from 7075-T6 aluminum.
Old 04-10-2009, 02:56 AM   #8
YarisSedan
Just went out to my car in the garage and realized it dosnt really matter what it looks like cause you will never see it unless you are under the car.
Old 04-10-2009, 09:24 AM   #9
mikenacarato
SIPNDEW
Drives: 15 STI
well i had a friend at a machine shop around the corner do the rod machining, other than that i screwed everything together. haha
i dont plan on selling them as there probably would be enough interest to keep costs low enough for people to want to buy. i suggest if you do want them get in on the group buy while you can in the suspension thread. if you do want a set like mine it will probably cost the same, maybe a tiny bit more as the grade of components is very high. contact me if you do though.
Old 04-10-2009, 09:28 PM   #10
jdinrc
jdinrc's Avatar
Drives: 2009 Yaris Blazing Blue 3dr
Are you going to powder-coat or paint the rods? The 7075-T6 isn't the best as far as corrosion resistance goes, and if you don't want to continually inspect them for corrosion, and if you don't paint them, you should at least alodine them.
jdinrc is offline   Reply With Quote
Old 04-11-2009, 12:02 AM   #11
The rods in the group buy are stainless, I think. These are beautiful, I would definitely powdercoat them for myself. TRD red, of course.
Old 04-11-2009, 10:19 PM   #12
mikenacarato
SIPNDEW
Drives: 15 STI
as of right now they are not powdercoated. i knew i would be making some changes to them (ie, notches to turn with wrench as so forth), but they will be coated. just test driving with them now.
Old 04-12-2009, 03:12 PM   #13
severous01
u guys need to check out coleman racing.com and a-1 racing.com. u can get all those parts for really cheap. look for aluminum control arms in whatever length u want. i ordered a 39" rod with 2 rod ends for my panhard rod on my camaro, and ia also ordered 2 15" rods and 4 rod ends for my lower control arms. u can order heim spacers and any bolts/nuts you want. total cost for HIGHEST grade, teflon lined, chromoly rod ends and the aluminum rods and spacers was about 140 bucks. u can't even find a set of control arms alone or a PHR alone for less than that.
any way...there's plenty to do with these two sites combined...custom aluminum hat rotors and custom calipers for just about any car....ULW(ultra light weight) anything u want...and it's MUCH cheaper than aftermarket but u gotta know what u need/want
First road trip with the scanguage talnlnky Fuel Economy Forum 5 04-07-2009 08:58 PM
90% on short trip. What to do to protect engine? lh59 DIY / Maintenance / Service 22 12-17-2008 09:02 AM
Auto Shop Local Bay Area Genuine Toyota Parts Low Low Price with Warrenty YarisSedan California 1 10-31-2008 08:32 PM
just completed cross-country trip (Philly to Newport Beach CA) carlgt1 California 6 09-24-2007 10:19 PM
Yaris cross-country trip preparation (Philly to LA) carlgt1 California 2 09-06-2007 10:50 AM
