Old 08-02-2009, 07:45 PM   #1
KooKatt
Drives: Yaris 5-door Hatchback 1.5L
Yaris in Thailand needs help with suspension tuning
I use Yaris G-limited in Bangkok. The road condition here is not very good. Hence, I would like to improve the suspension without dropping the car height. I would be grateful if you can give me some suggestion.
So far, all I did is install Ultra Racing rear sway bar. Since it is not a popular tuning here in Thailand, I can only find 16mm sway bar. I know that it might not be as good as 23mm but I think it is better than none at all. Do you think it is worth upgrading to 23mm?
Another thing that I need some more input. I would like to replace OEM shock and spring. Tein and TRD Sportivo package are very popular here but I found the ride is too low. And to be honest, it is rather uncomfortable driving these setup in Thailand. Thus, I am exploring other option. One solution I think is that I will use OEM spring from Yaris S-limited which is a bit lower (10mm) and more firm than mine OEM setup with some improve shock absorber e.g. TRD sportivo or Kayaba New SR Special. Or I could just use my current OEM spring with Kayaba Excel-G.
Any opinion or suggestion are welcome and greatly appreciate.
Thank you
KooKatt is offline   Reply With Quote
**SAFETY RECALL!! 06-07 YARIS HB & SEDANS** slvryaris DIY / Maintenance / Service 83 09-30-2012 01:25 PM
Yaris from New Zealand model - some differences to Canadian RS Yaris model Super_BQ General Yaris / Vitz Discussion 0 07-23-2007 03:54 AM
