Old 08-13-2009, 09:39 AM   #1
soloecho2
soloecho2's Avatar
Drives: 2004 Echo HB
Lapping Setup Suggestions
I am looking at Changing the set up on my 2004 3dr ECHO HB Currently the car is used primarily used for comutting 185 km each day. The car weighs 1800 lbs. Tires are 195/50/15 Falken 912s and I am happy with them. Camber LF is -0.75 RF is -0.83. Castor LF is 1.4 RF is 1.41. Toe in 0.01. Any input is appreciated. Tires alternates in 195/50/15 or 195/55/15 ? Maybe change the caster to -1.3 if it won't cause excessive tire wear. Please let me know what you guys think. Thanks Again.
soloecho2 is offline   Reply With Quote
Old 08-13-2009, 09:49 AM   #2
Tamago
Tamago's Avatar
Drives: UZJ100
i'm pretty sure you cannot change your caster measurement.. did you mean camber? if so, -1.3 will not affect your tire wear to the point of damage. get that toe to 0 though. i'd recommend looking at the rear alignment, see if you can eke out a little more neutral toe (the stock toe is on the "in" side pretty heavily)
Old 08-13-2009, 08:22 PM   #3
rob323
Don't drive it, RALLY it!
Drives: 1999 echo PRC rally car
Funnily enough, I have two sets of stock Echo front strut tops at home and one set has noticably more castor offset than the other set. I'll have a look sometime to see if there are part numbers on them.
rob323 is offline   Reply With Quote
Old 08-13-2009, 08:52 PM   #4
soloecho2
soloecho2's Avatar
Yes I did mean camber. Your right about the rear. LR is toed in 0.15 RR is toed in 0.10 for a total of .25. Any idea how much would I have to shim the front of the rear hubs to zero out the the toe in ?? Sorry I made a mistake on the front it is toed out 0.01.
Old 08-13-2009, 10:05 PM   #5
Tamago
Tamago's Avatar
Drives: UZJ100
put a couple stainless washers (one under each "lower front" axle bolt, the bolt that holds the hub to the axle) you should shoot for a 3/8" washer, should be able to get them pretty cheap. i run one each on the front lower bolts on my xA (same axle) and have achieved a toe-out in the rear. very slight, but made the car rotate much better :)
Old 08-14-2009, 07:00 AM   #6
bribri
Drives: white stock yris
Hi Solo,I ran two washers on the bottom and had about -2 .00 camber front and back. I had steel 14" wheels w/185-60-14 A/s ultra high performance tires.You whipped my a-s at mosport. I have switched to one washer (botttom front) but had to lower tire presser in the rear because the car felt unstable in 120 km/h turns. I' trying very used falcons 512 195/60-15 on aluminum 15" rims at Cayuga on Sunday. Im thinking you might do better times with sticker tires, more negative camber wiit a smidge of toe out. But most of all we all need more seat time more then anything. Its the driving not the lap times.
bribri is offline   Reply With Quote
Old 08-14-2009, 06:04 PM   #7
Tamago
Tamago's Avatar
Drives: UZJ100
bribri, best thing you could do is never buy 512's again. out of every tire i've had on my car (at least 10 different brands/styles) the 512's were the worst performers. granted they were in a 205 55 15, probably not what you're running..
Old 08-15-2009, 10:27 PM   #8
bribri
I found four 15x5.5 wheels for $60. Those tires came on them and the are worn to the markers. I'm going to finish them off at a small local track on sunday. They still grip better than the bridgstone 960 pole a/s that I have on stock 14' steelies.
I'm still a novice driver on the track so it doesn't matter which tire I use. How much flex do you get from a steel wheel compared to an aluminum alloy one?
Old 08-16-2009, 07:36 AM   #9
Tamago
Tamago's Avatar
Drives: UZJ100
none, on either wheel, especially on a street tire
July 26th Shannonville Full Track lapping event! 9th event of Touge.ca! Touge.ca Canada 1 07-30-2009 03:23 AM
August 2nd Mosport DDT lapping event. 2009-10th Touge.ca lapping event! Touge.ca Canada 1 07-30-2009 03:12 AM
July 5th Mosport DDT lapping event, 1:00-5:00pm! 2009-7th Touge.ca lapping event! Touge.ca Canada 0 06-04-2009 06:47 AM
2009 Track lapping events, Touge Motorsports, www.Touge.ca. Touge.ca Canada 3 04-26-2009 04:49 AM
November 2nd, Sunday - Mosport DDT lapping event, Last event of the season!! Touge.ca Canada 0 10-31-2008 12:45 AM
