Old 11-15-2006, 10:36 PM   #1
jbann
Drives: 07 yaris 3dr mblue
HELP Plsneed ecu diag/ecu pinout vvt-i controller install
Hey guys i need help need to find what wires are coming from ecu and im trying to hook up a few things and need to tap wires at the ecu. im installing a camcon vvt-i controller any help is great i kno u guys will come through
jbann is offline   Reply With Quote
Old 11-15-2006, 11:12 PM   #2
KSIbucky
KSIbucky's Avatar
Drives: 2007 Yaris manual dark silver
Send a message via AIM to KSIbucky Send a message via MSN to KSIbucky
http://rds.yahoo.com/_ylt=A9gnMiZB6V.../pe_camcon.htm
7 Color Tach
Fujita Intake
Momo pedals Shift knob and boot. Full TRD SSK.
Blitz exhaust
Megan Lowering Springs
(Next is DC Header)
KSIbucky is offline   Reply With Quote
Old 11-16-2006, 04:56 PM   #3
Katana
Katana's Avatar
Drives: Yaris LB 1.3lt 06
What are you planning to do???
Old 11-16-2006, 08:48 PM   #4
jbann
I jsut need to wire up the camcon to the vvt-i signal, a/f signal and rpm+/- signal
Old 11-16-2006, 10:29 PM   #5
Lafiro
Drives: 06 Yaris Sedan
2nd that question..
Old 11-16-2006, 10:42 PM   #6
Black Yaris
der Zeck
Black Yaris's Avatar
the hip bone's connected to the theigh bone.... the theigh bone's connected to the..... what the hell is going on here?
Old 11-17-2006, 02:05 AM   #7
Sounds like a device to override the default VVTi engagement point, to tweak the response of the engine... Let us know how it works out, I'm quite interested in this!
Old 11-17-2006, 08:51 AM   #8
Katana
Katana's Avatar
Some guys in Greece tried that out and unfortunately it did not gave very good results.
Old 11-17-2006, 11:06 PM   #9
jbann
Yeah it controls are vvti engagement like vtec controller and controls a/f
Old 11-18-2006, 03:36 AM   #10
Katana
Katana's Avatar
And the gains in HP aren't that much...
Old 11-18-2006, 10:12 AM   #11
Toyotech
Your Toyota Technician
Drives: 06 Cobalt SS/SC, 06 Rolla S
Send a message via AIM to Toyotech
Originally Posted by Thirty-Nine
Woah, woah. VVTi doesn't engage like VTEC. That's VVTL-i.
VVTi is continuously running. From what I understand, this is basically an air/fuel controller, similar to the Apex SFAC.
vvti is similar and if it not continuously running... its oil pressure activated.
the camcon does not show such good gains on the 1zz so i doubt you will see much on the 1nz
Toyotech is offline   Reply With Quote
Old 11-20-2006, 11:15 PM   #12
jbann
thanks everyone for replies dont my sole point of the camcon is to make minor adjustments to vvt-i and a/f ratio not to extract mass hp from it, these adjustments also make the car more efficient, want to strength the entire rpm band, mods so far intake, 4-2-1 header obx(scion xb) custom installed with 2" piping removing 2nd cat n resonator. just need ecu diagrams thats it will post my results, thanks
