Old 02-05-2011, 05:33 PM   #1
dlplunkett44
Drives: 07 Yaris 4-Door
HELP: changing water pump
I am in the process of changing my water pump, but I cannot get the engine mount off. I've removed all 5 of the bolts, but where it connects to the engine half of the mount, it will not come seperated. There is a bolt hole where you can screw in one of the bolts to seperate the two, but I tried that, and the threads inside of it are now gone, so I can't use that. Is there any way that I can get this water pump off without removing the engine mount? I have the water pump loose, but I cannot seem to orient it in a way to remove it. Please help, I need to finish this very soon; I need the car tomorrow morning.
dlplunkett44 is offline   Reply With Quote
Old 02-05-2011, 10:19 PM   #2
The engine mount should come off fairly easily. You do need to support the engine when removing it.
Old 02-05-2011, 10:25 PM   #3
auxmike
auxmike's Avatar
I used a big three ft. prybar to push the engine sideways without ever messing with the engine mounts. It's fast and save a LOT of time...
Old 02-05-2011, 10:45 PM   #4
^ +1
Old 02-06-2011, 09:26 AM   #5
Klink10
Klink10's Avatar
I never had to remove the mount or have to pry anything to remove mine.
Edit to add that I removed the pump pulley first and the angled the bracket holding the AC line. Having the NST pulley helped alot.
Water Pump issue, after taking in for Recall GeneralDon7 General Yaris / Vitz Discussion 34 05-27-2012 08:04 PM
Yaris Fuel Pump HTM Yaris General Yaris / Vitz Discussion 12 03-22-2012 03:34 AM
Water Pump leaks and then stops CB900F2 DIY / Maintenance / Service 30 05-09-2011 09:14 AM
Hmm my water pump failed again!!!! Could it be the pulley?!?! YarisSedan Performance Modifications 64 10-05-2009 09:32 PM
