![]() ![]() Drives: 2011 Toyota Yaris Join Date: Jan 2011
07' Instrument Panel in 11'?
I want to put a 2007 instrument panel into my 2011 as I like the look of it better. My question is, can I do it myself? Will the Milage I have override whatever the last milage was and will the gas gauge and everything else sinc up and work or will I need reporgramming of the old cluster by the dealer before installing? Does anyone know if all the connections are the same? Can I just plug and play with the old cluster in my new Yaris? I really like the look over the orange cluster I have.
#2 | |
Gas gauge, etc. will be fine, as they work off live sensors. The big issue for you will be the lack of ABS, TRAC, and VSC indicators for your 2011, since the 07 cluster won't have them. And, yes the connectors/pinout are the same. I have an 08 cluster that I swap back and forth on my 09, as I am doing my YarGauge development and testing.
Do you have any info for those third part companies ? I was lucky enough to find a "s" model cluster with the tach and i would like to get the mileage changed if possible.
Why is that a big issue? The 07 do have ABS lights? Dont know what the VSC is or why the TRAC light would be an issue? But maybe should keep orginial cluster?
noob-toob
Drives: 2007 yaris 4dr sedan Join Date: Sep 2010
i have a 2007 yaris sedan, and it has the light for the ABS. or it may just be a canadian thing
|| "it's a tough job, but somebody has got to do it" ||
Do a web search for odometer repair service
#7 | |
ABS wasn't all that common prior to 09, so finding a cluster with it might be tough. Traction control and vehicle stability control were new in 2010, so no clusters prior will have the indicators for those. Another option is to change the LEDs. There is a good thread on here with a DIY on changing them.
| what is behind the instrument panel | henry33 | DIY / Maintenance / Service | 3 | 12-10-2010 10:16 PM |
| Instrument Panel Light out? | ApolloX | DIY / Maintenance / Service | 2 | 09-28-2010 06:56 PM |
| Instrument Panel goes out if I turn on my lights | ceceb | DIY / Maintenance / Service | 9 | 07-08-2010 06:56 PM |
| Question about replacing Instrument Panel!! | Wowzers78 | General Yaris / Vitz Discussion | 0 | 03-18-2010 10:25 AM |
| New instrument panel | fmicle | DIY / Maintenance / Service | 17 | 07-19-2009 10:09 PM |
