Old 07-13-2011, 10:57 PM   #1
david.gartee1
Drives: 2007 Yaris HB
Speedometer
I recently installed a new HU that I had in my previous car. It is a nav unit that uses the VSS to show me on-screen the speed, g's, and all that. Well, the HU seems off from the speedometer by about 5-10% (haven't really done the math). I thought it might have something to do with the wire not being connected correctly. Even more recently, I downloaded an app to my Android phone that shows the MPH using the internal accelerometer and GPS, and the two are very close to the same.
I was not told when I purchased the car that there have been any mods done to the wheels, transmission, or anything that would case the discrepancy. Does anyone know what I should look for to find out, or should I just believe the speedo? If it is wrong, that means that the trip meter, odometer, and everything else is incorrect, also. I'm hoping that is not the case. And before anybody asks, no I have not yet driven with someone following me to see if they have the same speed. I will do that some time and post an update, but I would like to know what other people on here think in the meantime. TIA
david.gartee1 is offline   Reply With Quote
Old 07-13-2011, 11:23 PM   #2
Lil Abner
Drives: 2009 3dr LB Manual
Which are very close? The Headunit and Android phone? Factory speedometers can be off by several percent just due to tire sizes. 14" rims and 15" rims use slightly different tire diameters (the outer diameter). If the previous owner changed tires, there's also the chance the tires of slightly larger or smaller. What size tires does the car have currently? Oh, and on my 2009, my Scangauge and GPS read the same, the speedometer on the dash is off by about 1-2mph at 60mph.
Old 07-14-2011, 12:24 AM   #3
david.gartee1
Sorry, the Android app and the HU are very close. My tires are 185/60r15 made by GoodRide. It looks as if the wheels are the factory steelies.
Old 07-14-2011, 10:14 AM   #4
Lil Abner
Honestly, I think your Android and HU are correct, the car is a bit off. But yours is just like mine. The tires are within the factory spec, so you're good there. The needle isn't adjustable, so you're basically stuck. But the majority of cars have the speedo off by a little bit. I'd say just get use to it. Like I said, for me, I can set my cruise at "60", but I'm actually doing 57-58.
Old 07-14-2011, 07:13 PM   #5
Kiteless
Kiteless's Avatar
Drives: US 2007 Yaris Liftback 5MT
If I go 65MPH on the odo, GPS says I am going 61mph. Mine are stock 14" steelies. So I go 70mph on the freeway and that gets me like 66mph or so.
2007 Toyota Yaris Liftback Base 5 Speed.
Mods: Netz/Vitz/RS badging, RS style spoiler, RS replica tails, Tenabe NT210 Springs, Tokico Blue Struts, Team Dynamics 14", fogs(Arrived), JDM HKS Exhaust.
Kiteless is offline   Reply With Quote
Old 07-15-2011, 03:32 AM   #6
david.gartee1
Wow, mine is the same way. That just does not seem right. Over the life of the car, that could mean the real mileage is off by thousands. Not to mention the true MPG. I like to know that I can look at my speedo and know my real speed. Seems to me like Toyota should do something about this. I was cruising down the interstate at "80" tonight, and my GPS said 74.5-ish. To me, that is a problem.
gps, mph, speed, speedometer
!! Speedometer Needle Problem !!! Murtaza_murti Cosmetic Modifications (Exterior/Interior) 40 11-25-2014 11:48 AM
Speedometer Accuracy? YarisPete DIY / Maintenance / Service 37 11-29-2013 03:00 PM
speedometer walt101786 Cosmetic Modifications (Exterior/Interior) 0 10-09-2010 10:03 PM
No speedometer or tachometer lights during day cdavidhess DIY / Maintenance / Service 20 06-30-2009 11:38 AM
Speedometer Error? MadMax General Yaris / Vitz Discussion 18 02-27-2009 08:22 PM
