Old 09-15-2010, 10:29 PM   #1
marlondog
Shut your fricken suck!!!
marlondog's Avatar
Drives: 07' liftback
Which adjustable front sway bar endlinks work on the Yaris?
A couple of months back I purchased KSPORT coilovers, and could drop it no more than 1.7" in the front. It seems that a shorter endlink would allow me the loosen up the springs a little, and allow me to thread the perch up a little more for a better drop.
The only problem is that KSPORT doesn't make one for our car, and that's why the coilovers didn't come with any. That leaves me with no other choice but to buy one for a different car(Fit,MR2,Mini) or buy one for the Yaris, but a different manufacturer of Coilovers(Kido,Megan,Tein,etc).
If any of you have had experience with endlinks, I would appreciate your imput.
File Type: jpg suspension_tms_adjustable_swaybar_links_lg.jpg (18.3 KB, 172 views)
marlondog is offline   Reply With Quote
Old 08-31-2011, 05:54 PM   #2
lkev
Drives: 07 Yaris
having the same problem, have you found a solution?
lkev is offline   Reply With Quote
Old 08-31-2011, 06:33 PM   #3
I'd need to see a picture of the end link attachment point, but in my experience, end links have nothing whatsoever to do with ride height.
Much easier to buy a shorter spring!
Marlon, did you remove the height adjustment rings completely? That should give you more drop.
Old 08-31-2011, 06:52 PM   #4
Jason@SportsCar
+1 Looking at the images of the Yaris kit, those K Sport springs are way to long. Just order the appropriate length/rate ones from Eibach or Hypercoil.
Old 08-31-2011, 06:53 PM   #5
liam6200
Drives: 2010 Yaris 1.4d
what about these: http://cgi.ebay.com/ebaymotors/_W0QQ...KQ3aMEWAXQ3aIT
liam6200 is offline   Reply With Quote
Old 08-31-2011, 06:58 PM   #6
Jason@SportsCar
Originally Posted by liam6200 View Post
Just a matter of if they will go short enough to allow the swaybar collar to be lowered on the strut. Powergrid makes good parts, knowing now that they have a Yaris application, they could likely make a custom shorter one if needed.
Our car is very low, and we use the stock endlinks, but only a 6" long spring.
Old 08-31-2011, 10:42 PM   #7
Lil Abner
Drives: 2009 3dr LB Manual
Or, if you purchased something like the kit you show above, you can just tap more threads to the shaft, and cut it down as short as you want. Or another option would be to purchased your own threaded rod, cut to length, to fit.
Old 09-01-2011, 01:21 AM   #8
ljming99
Drives: Yaris '06
Thats partially true.
Im having similar issues with the Ksport coilover as well.
For the front, the mounting point for the sway bar is adjustable - great if you can find an adjustable sway bar.
For the rear, i find the spring too short - no matter how i adjust - the maximum gap i can get is about 2 fingers(from the top of the tire to the body-wheel arc).
ljming99 is offline   Reply With Quote
Old 09-01-2011, 04:49 PM   #9
lkev
Drives: 07 Yaris
For my car the endlinks are both basically pointing towards
Eachother and I hand to step on the sway just to get the
Top link to fit into the strut bracket. Not sure if that's the load
These things are meant to carry. It also might be because my
Car was jacked up on one side I had a hard time getting it in
Old 09-01-2011, 05:20 PM   #10
is this without the adjustment rings (front) and perches (rear)?
Old 09-01-2011, 05:20 PM   #11
Jack up the front (both sides) to do the fronts and the rear (both sides) to do the rear.
Old 09-01-2011, 05:21 PM   #12
I don't understand this. Don't the end links attach to the sway bar?
Old 09-02-2011, 08:15 PM   #13
MUSKOKA800
MUSKOKA800's Avatar
Are you running staggered ride height (front left - front right) or tuning for specific turns (roundy-round racing)?
If not, adjustable links aren't necessary. The OEM units work fine.
Old 09-02-2011, 09:08 PM   #14
marlondog
marlondog's Avatar
I can't believe y'allz brought this thread back almost a year of sleep. I finally figured out how to adjust the shocks and go as low as I wanna. Thanks for your imput.
Old 09-02-2011, 09:11 PM   #15
ljming99
Drives: Yaris '06
I have posted some pictures in another thread.
http://www.yarisworld.com/forums/sho...ghlight=ksport
Take a look at the first 1. Alot of other coilovers, the mounting point for the linkage is fixed as the often used back the original ones.
For Ksport, it allows you to go really really low with the ride except you will need the adjustable linkage like the in the picture which TS has posted.
Also check out my Front installed photo and you will probably know why.
Stock Front Sway bar kngrsll Tracking, Racing, Auto-X Forum 4 07-04-2009 07:01 PM
2006-2007 Yaris 4 Door Front Strut Bar AEM/DC Sport KenAEM Performance Modifications 2 10-07-2006 02:26 AM
