Old 05-08-2012, 12:41 AM   #1
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Exclamation 1NZ-FE Block Housing Thickness (Oil Pan Sub Assembly)
To give you perspective of what you are working with when tapping the block housing for any type of fitting.
Old 05-08-2012, 01:47 AM   #2
Is that hunk from the side of the block? yeah, that's THIN
Old 05-08-2012, 08:28 AM   #3
gotta keep it lightweight somehow!
Old 05-08-2012, 11:00 AM   #4
fnkngrv
fnkngrv's Avatar
Post
yes. the place where the two pennies is sitting is where the fitting had been.
Old 05-08-2012, 12:29 PM   #5
Which also demonstrates the need for a fitting with a retainer washer/nut on the inside.
Old 05-08-2012, 02:13 PM   #6
fnkngrv
fnkngrv's Avatar
Unfortunately yes. I spoke with two welders here that are considered very good to excellent with welding aluminum. Neither would touch my motor. They both would have tack welded a plate to the outside of the assembly to reinforce and "thicken" the mounting point however with the lack of thickness in the first place as well as the ridges in the assembly they didn't feel confident that it was a proper solution therefore the sandwich type fitting is the only route that I have at least.
Old 05-08-2012, 02:43 PM   #7
Focus_Sh1ft
Focus_Sh1ft's Avatar
+1
When I tapped the block for the return I remember getting comfy thinking I was going to be there for awhile. I was through it 5 seconds later
Old 05-09-2012, 12:30 PM   #8
Schizoprenia
Drives: Toyota Yaris 1.5 M/T '06
now that's funny. lets see how long i'd spend at the mechanic this weekend.
but the hard parts is removing the right side front axle no ?
Schizoprenia is offline   Reply With Quote
block, fitting, oil, return, tap
DIY: Engine Grille Block BailOut DIY / Maintenance / Service 39 11-11-2017 10:33 PM
engine block heater linny DIY / Maintenance / Service 6 01-19-2012 12:22 PM
HOW STRONG IS BLOCK OS 1SZFE Faraz_Shaikh General Yaris / Vitz Discussion 1 01-05-2011 07:49 AM
Block guard Paris vvt-i Performance Modifications 13 12-19-2009 01:55 AM
1NZ port & polish ChinoCharles Performance Modifications 75 06-01-2009 07:39 PM
