Old 03-28-2012, 01:43 PM   #1
thetut
Drives: 2007 4dr sedan
Wheel Stud specs
I'll be changing over from winter to summer tires and would like to clean up the stud threads with a die. Does anyone know what size die I should use?
thetut is offline   Reply With Quote
Old 03-28-2012, 02:00 PM   #2
TOLMACH
Drives: soarer
studs have 12 x 1.5 mm thread
your studs are rusty? why not just clean /grease them? (to grease is usually not a good advice but needed sometimes)
Old 03-28-2012, 02:14 PM   #3
thetut
Thanks but I think the problem is not so much rust or dirt but with an over enthusiastic tire changer who was in love with his air tools' power.
I'm not sure if the threads have been stretched or not so I want to try the die before I resort to changing the studs.
Old 03-28-2012, 02:18 PM   #4
TOLMACH
Drives: soarer
I see.. I had sumilar problem couple years ago.. in my case I had to replace all nuts (lugs) (and couple studs)
Good luck anyways
Old 03-28-2012, 02:28 PM   #5
thetut
Thanks. I appreciate the info.
Old 03-28-2012, 02:52 PM   #6
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
You should have that guy just put up the cost for new ones.
Old 03-28-2012, 04:11 PM   #7
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
yea exactly. I would flip if someone wrecked my lugs/studs etc.
Colin Chapman disciple
Old 03-28-2012, 04:14 PM   #8
1.5
Form>Function
1.5's Avatar
everytime i look to see who the most recent post belongs to in a thread and I see "why?" it always throws me off lol
Old 03-28-2012, 07:50 PM   #9
why?
why?'s Avatar
Drives: Yaris LB
indeed. one of many reasons i love to use it as a handle.
Old 03-29-2012, 12:40 AM   #10
CoryM
Drives: 2009 5-door, 5-speed
Have a look for a "thread chaser" rather than a die. They are made to clean up threads rather than cut new ones. Will work better (cheaper too).
When over-torqued it's often the lugs that get damaged. The small end of the taper gets pinched in causing it to be tight on the lug.
Cheers.
Old 03-29-2012, 03:22 PM   #11
thetut
Thanks. Will do.
The Yaris Steering Wheel wornways General Yaris / Vitz Discussion 12 10-09-2012 01:41 PM
Broken Wheel stud !! vten Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 08-26-2011 10:04 AM
How much would you pay for a warranty supported steering wheel extension? (3d try) wornways General Yaris / Vitz Discussion 36 09-16-2009 10:16 AM
