![]() ![]() Drives: Black 2012 Yaris 3door 5speed Join Date: Dec 2011
Trailer hitch wiring yaris 2012
I was going to post this in the electrical section but this is a problem with a new 2012 Yaris.
This past week end I used my multi-meter to find which wire goes to what in the left rear tail light connector after I removed it from the socket. I was happy to find, running light, brake light, and left turn signal. I used the fast splice connectors to attach the wires from the 5 to 4 wire converter. I than found the right turn signal in the right rear tail light plug. I was done. I used the multi-meter to check the power out put on the plug which goes to the trailer. Everything seemed fine. As a note, the ground is fastened under the screw to the tail light which seems like a strong ground. I hooked up the boat trailer harness and turned on my various lights. Not a glimmer. After disconnecting the car from the boat, I got my 12 volt battery out and using a couple of leads, I tried each wire plug on the trailer. Each test on the trailer lights was successful. I also re-tested the car plug and found only 4-5 volts coming from the taillight. After the key had been out of the ignition for 5 minutes, the voltage was back to 12 volts on all plug connects in the car. After double checking which wire gets power from what circuit and finding every plug connection was ok, I tried again to power up the trailer lights same result. Back to the drawing board.
New to the Toyota World, be nice. |
Sounds like you need a wiring harness which takes a direct power feed from the battery.
You need a trailer wiring converter. It won't require any additional wiring from the taps that you already did, but it will properly isolate the trailer lights from the car's lights, preventing the voltage drop.
Thanks for the suggestions Guys.
I do have a similar wiring converter installed CTScott, it's not a Hopkins but has the same extra brake wire lead which is needed because of the separate signal bulb. I was really hoping it wasn't because I needed a separate power supply due to draw WeeYari but it does sound like something is shutting down due to a lack of power. Next chance I get I'll run the converter to the larger main bulb wires instead of those hair like wires from the main plug and hope that solves it. Any other suggestions are welcome, please.
#5 | |
The trailer lights are bulb. Duel elements, running lights and brake/signal.
#7 | |
Also, to verify your wiring, one the 2012 tail light connectors: Taillight - Green wire on either right or left Stop - Light blue wire on either Right Turn - Sky blue wire Left turn - Yellow wire Ground - White/black (or bare metal bolt connection)
#8 | |
The bulbs on the trailer are just standard trailer bulbs which work great when hooked up to my Dads 2007 Yaris. I will try and get a resistance reading as you suggested (yes it's a 4 prong plug, one being ground) when the weather clears. Could it be a faulty converter? I've never come across one in my time but I'm tempted to buy another one to see if thats it.
#9 | |
Great idea CTScott. I'll do that this weekend.
So after work I tried to hook up the converter again.
I spliced in the running lights right to a running light bulb which I checked with my tester. Plugged in the trailer and the running lights where on. I then spliced into the left signal light and tried that. Worked great. I then spliced into the right turn signal and it worked great. I then spliced into the brake wire at the bulb and had my son push the brake pedal. It worked great. Thought I was all set but then, I put on the 4 ways. The rear trailer lights flashed but they were dim. I stopped that and turned on the running lights again, nothing. I tried the left signal, both signal lights flashed dim. I tried the brakes, nothing. I SHUT IT DOWN. Tomorrow I will pick up a powered trailer light converter and see how that works. Why are they making the wiring in almost every car so frustrating these days?????????
#12 | |
Ahhh, and in laymans terms that means???? Sorry CTScott, I'm not following.
#14 |
It means - Yes, you need the powered converter. Integrating the turn signal driver into the cluster means saving a few dollars and that it will have less drive capability.
#15 |
Thanks for the translation CTScott. I'm feeling a little more confident now.
#16 |
Post#2 FTW.
#17 | |
It all works! ![]() Thanks WeeYari and CTScott for the assistance. Note, the ground at the left tail light isn't the best. I used one of the studs coming from under the hatch floor as a ground and the voltage stayed true.
| Do you like the 2012 restyle? | hitmoninfinity | Third Gen Yaris General Discussion | 106 | 04-14-2016 09:08 PM |
| 2012 Yaris at SEMA | Jason@SportsCar | Third Gen Yaris General Discussion | 5 | 09-23-2013 04:55 AM |
| 2007 Yaris Pricing Info ! | YarisBueller | New YARIS Purchase Forum | 104 | 06-24-2009 05:54 PM |
