Old 04-30-2014, 10:13 AM   #1
regal
Drives: 09 Yaris 3 Dr White LB
Door Key ?
I spun out on the ice this winter so I had to replace the drivers side door with one from the JY.
She's as good as new except one minor detail: a didn't get the key for the door when I bought it. Its an 09. Is there anyway to find the right key for this I wouldn't mind a second key, one for ignition one for the door.
regal is offline   Reply With Quote
Old 04-30-2014, 10:47 AM   #2
regal
OK this is silly. I have the VIN number from the JY door. But that's not good enough you have to be a paying dues locksmith to get a key code from the VIN, stupid.
Any other way?
Old 04-30-2014, 11:17 AM   #3
Any other way?
If you remove the lock assembly and bring it to the locksmith with your original key, they may be able to re-pin the lock to match your existing key.
Old 04-30-2014, 07:56 PM   #4
regal
Probably take me 2 hrs to remove the lock another 2 hrs at the lock smith, can go into work and make $500 for 6 hrs so not worth it.
I found a company that can give you the key code from the VIN + techstream ECU dump for $12 that sounds like fun I may try that route.
Old 05-01-2014, 08:24 AM   #5
bronsin
bronsin's Avatar
Why not just lock the drivers door with the button and open the passenger door with the key you already have?
BTW I am 58 this year and have never locked my doors and nothing bad ever happened.
I guess that's because I don't own cars anyone would want to steal and I don't leave anything in the car ditto.
