Old 01-05-2015, 12:08 AM   #1
428CobraJet
Drives: '09 Yaris 3dr, 13 F150rcsb 5.0
seat bolster worn
My outer driver's seat bolster has worn thru (in addition to the foam getting lumpy there). 09 3 door. 122,000 miles.
What are my options?
Suggestions?
Craig
You are what you drive.
428CobraJet is offline   Reply With Quote
Old 01-05-2015, 01:37 PM   #2
428CobraJet
A complete new drivers seat would be about $1350 (1147.04 plus 200 shipping). Certainly the driver's seat would look and feel like new. Hopefully would still match the patina on other soft goods.
New Katzkin leather installed with slight repairs on bolster would be $900 plus tax (approx975) installed...would feel? Would probably look great.
Old 01-05-2015, 07:18 PM   #3
Check car-parts.com and see if there are any used low-mileage ones out there.
Old 01-05-2015, 11:02 PM   #4
428CobraJet
Thanks!
What year would match? 09 and 10? Mine is solid blackish.
Old 01-05-2015, 11:05 PM   #5
Originally Posted by 428CobraJet View Post
Thanks!
09-11 would be a match for yours.
Old 01-05-2015, 11:06 PM   #6
428CobraJet
Non S 3 door only?
Old 01-05-2015, 11:27 PM   #7
Non S 3 door only?
For driver's side 5 door (4 door htchbk on there) would be fine as well. Must be w/airbag for 09-11.
Old 01-05-2015, 11:29 PM   #8
428CobraJet
Thanks!
Old 01-06-2015, 05:56 PM   #9
CoryM
Drives: 2009 5-door, 5-speed
May want to visit a local car upholstery shop. May be able to get it re done for less than you think.
Old 01-06-2015, 06:57 PM   #10
428CobraJet
Since the upholstery is glued on...im not so sure. Thanks to CTScott...I'm gonna look at some used ones. I'll keep y'all posted.
Old 01-07-2015, 12:52 AM   #11
CoryM
It just pulls off and can be re-glued. I've done heated seats on mine that way and looks good. I've also had LOTS of bolsters repaired on work trucks and they usually look just like OE after.
Old 01-07-2015, 07:59 AM   #12
I was initially going to suggest that route for him, but there seems to be quite a few junkyard seats available in Texas for under $150.
Old 01-12-2015, 04:23 PM   #13
428CobraJet
Thank you so much gentlemen! $85 plus tax off a 2010. Donor car was hit in front relatively minor. Clean insides with doors and glass intact. 6 miles from home! No charge for armrest!!!!!!
Any tricks on the swap due to the airbag?
Old 01-12-2015, 07:58 PM   #14
Just disconnect the battery to be safe while doing the swap. Other than that, you scored a hell of a deal.
Old 01-13-2015, 12:34 PM   #15
428CobraJet
All done!
Thanks again.
DIY - Replacing the Front Seat Cushions CTScott DIY / Maintenance / Service 6 10-04-2016 07:39 PM
seat upgrade needed-options? OTB Cosmetic Modifications (Exterior/Interior) 8 12-12-2012 10:01 PM
Clazzio Seat Cover DIY Install PETERPOOP DIY / Maintenance / Service 31 09-10-2010 04:30 PM
Rostra seat heater and lumbar support sesmith In Car Entertainment + Electronics (audio / video / alarm) 1 01-03-2009 09:51 AM
Driver seat being worn away Kitt General Yaris / Vitz Discussion 6 11-07-2006 03:09 PM
