Old 05-06-2007, 04:27 PM   #1
Cathy
Drives: Yaris Hatchback
Air Conditioner Noise
Hello everyone,
Turned on my air to the highest level today and it was making a loud noise that could be heard over the radio, I can't begin to describe this noise, but when I turned it down to 3 there was no noise. My car is an 07 HB with less that 5,000 miles. Everyone in my family is automobile challenged so there isn't anyone I can begin to ask, so I came to the experts.
Has anyone experienced this or know what might be causing this? Is your air loud? I can't get to the dealer that I bought the car from until Friday, will any Toyota dealer honor the warranty?
Thanks in advance,
Cathy
Cathy is offline   Reply With Quote
Old 05-06-2007, 04:31 PM   #2
blacksan
blacksan's Avatar
Drives: 07 Bayou Blue Liftback
Originally Posted by Cathy View Post
Hello everyone,
Thanks in advance,
Cathy
Fan vibration noise?
You might want to check the AC filter access door behind the glove box. It might not closed properly. This is just a guess. If all else fails drive up to VA as I am off work do to injury for a couple of weeks.
blacksan is offline   Reply With Quote
Old 05-06-2007, 04:42 PM   #3
Blenjar
Blenjar's Avatar
Drives: Black Yaris 07 HB
I have a noise too.
I put circulation, press the A/C..when I'm not moving, i hear a BBBBBBBBBBBBBBBBBB...etc, whe nI move its gone...wtf is that?
Only happens when I got hte A/C button pressed.
The noise isn' noticeable when music is on but it happens..
-- Blen
Old 05-06-2007, 04:47 PM   #4
Ogredude
Ogredude's Avatar
Drives: 2007 Red Yaris RS
as long as its not a loud CLICKING TICKTICKTICKTICK, thats a sign of the compressor clutch about to go, but im sure these toyota ones are designed much better than that
Ogredude is offline   Reply With Quote
Old 05-06-2007, 04:53 PM   #5
blacksan
blacksan's Avatar
Is everyone using the outside air circulation vs inside air circulation when this occurs? I remember something about that in the manual. But, I might just be stir crazy from sitting around the house and just imagining the whole thing?
Old 05-06-2007, 05:16 PM   #6
Blenjar
Blenjar's Avatar
I use outside all times. Only use the inside when im driving in a smelly place or its really hottttttt outside, humid and need max A/C.
But my noise happen either way as long as A/C button is on.
-- Blen
Old 05-06-2007, 05:18 PM   #7
blacksan
blacksan's Avatar
-- Blen
Hummm, mine is quiet?
Old 05-06-2007, 05:23 PM   #8
Cathy
Thanks so much for the suggestions, I knew I could count on you guys! I'll check all the things mentioned. I appreciate your help.
Cathy
Old 05-06-2007, 05:25 PM   #9
Blenjar
Blenjar's Avatar
Well im almost at 10k miles..gotta do my oil change probably tomorrow or tuesday so I'll have them check this shit out...
-- Blen
Old 05-06-2007, 05:26 PM   #10
blacksan
blacksan's Avatar
Cathy
Dear Cathy,
This is the WWW and we are all "Super Hero's" with unlimited knowledge!
Yours truly,
Da Answer Man
Old 05-06-2007, 09:56 PM   #11
eco
eco's Avatar
Drives: 2007 Black Yaris sedan
Ive used ac about 5 times,no noise,the fan is directly brhind and to the right of the head unit.Since I have a home-made ac filter,I never put the fan on 4,this may help you.
eco is offline   Reply With Quote
Old 05-06-2007, 10:04 PM   #12
brickhardmeat
Lonesome Cowboy
brickhardmeat's Avatar
Drives: 2007 WHITE HATCHBACK
it's a locust
SPONSORED BY
Old 05-07-2007, 12:26 AM   #13
Black Yaris
der Zeck
Black Yaris's Avatar
Any Toyota dealership in the United States can take care of you
Old 05-07-2007, 11:07 PM   #14
Cathy
Thanks Black Yaris. Tried all the suggestions that were posted as of yesterday, and today it was making a "mooing" noise, (ok I'm a girl don't laugh), on level 3 and 4, and it's been in the 90's so it's got to be looked at. Probalby won't happen until Friday or Saturday, will let you all know what I find out.
Thanks again,
Cathy
Old 05-08-2007, 12:18 AM   #15
Typer73
Tired of the Stars!
Typer73's Avatar
Drives: '07 Meteorite LB
WOW! Did you get the cows engine option instead of the usual hamsters? Must be hard to keep 'em fed.
Many moons ago, I worked as secretary for a small automotive/body shop and I learned a valuable lesson from the mechanics there... Does it work? if yes, is it leaking anything? if no, don't worry so much about the noise it makes! Most noises are harmless.
Typer73 is offline   Reply With Quote
Old 05-08-2007, 12:57 AM   #16
Cathy
Does it work? if yes, is it leaking anything? if no, don't worry so much about the noise it makes! Most noises are harmless.[/QUOTE]
Well, I can understand that, but this car has less than 5,000 miles on it, and I live in the desert of southern California, so the air needs to work. I dealt with the air not working in my Tercel for the last 2 years of ownership, so this is a biggie for me. And unfortunately this noise is loud, couldn't probably carry on a conversation with the air on. Thanks for your advise.
Cathy
Old 05-08-2007, 02:08 AM   #17
Typer73
Tired of the Stars!
Typer73's Avatar
I'll see your SoCal & raise you a GA in the dead of summer... wet hot trumps dry hot every time! Had a noisy AC in the last car I had, cooled like a bitch... just had to turn up the stereo! Under warranty, def get it fixed, but don't obsess about it.
Cold Air Intake vs. Short Ram Intake nevermorez Performance Modifications 1 01-24-2007 04:25 PM
Air Flow switch problem aucorium DIY / Maintenance / Service 5 01-15-2007 04:54 PM
1.3 Ltr Yaris Air Filter mods aucorium Performance Modifications 9 08-18-2006 08:32 AM
Noise in the A/C System cburac DIY / Maintenance / Service 1 05-16-2006 06:14 AM
