Old 03-14-2016, 09:29 PM   #1
MUSKOKA800
MUSKOKA800's Avatar
P0327 Knock Sensor low input
Can anyone shed some light on what's involved to remedy this code?
Was accelerating from a stop. Noticed some knocking (first time). On comes the Engine light.
I've scanned it and found P0327, cleared it and it immediately lights the engine light again. Car seemed sluggish after. May have gone into a limp home mode??? I'll take a look for lose wires etc in the morning.
Old 03-14-2016, 09:57 PM   #2
That code indicates that the knock sensor has failed or the wiring to it has. The ECM will remain in fail-safe mode until it is resolved.
Old 03-15-2016, 01:19 AM   #3
MUSKOKA800
MUSKOKA800's Avatar
Thanks CTScott. I was hoping you would chine in. I will inspect in the a.m.
Can you advise where to look for it? Hopefully not to buried.
Old 03-15-2016, 08:25 PM   #4
It is kind of buried. It is a round sensor with black and white wires that go to green and red wires on the harness after its connector. It is located on the front of the block about 2" to the right of and 2" up from the thermostat housing. I can't remember if you can get it off without removing the intake manifold.
DIY: Adding AUX input to 2006 french Yaris - W58824 sven337 DIY / Maintenance / Service 4 04-17-2022 01:59 PM
Aux Input Wire nobleboy In Car Entertainment + Electronics (audio / video / alarm) 25 06-03-2015 06:25 AM
Rod knock or Main bearing knock? jabranko General Yaris / Vitz Discussion 27 08-05-2011 12:14 PM
High pitched whine using stock head unit / aux input? IsLNdbOi In Car Entertainment + Electronics (audio / video / alarm) 8 02-02-2007 01:49 PM
