Drives: Toyota Yaris 2008 Sedan Join Date: Oct 2018
Removing bolt off AC compressor clutch
Hello,
I have a 2008 1.5L automatic yaris sedan. There are bearings in the compressor pulley that have gone bad and the car makes a grinding noise. I bought a compressor clutch kit to replace the whole system. The problem is I can't remove the bolt that holds the clutch and pulley on. If I try to remove with a ratchet it just rotates the pulley with the belt. How do I get this damn thing off? Below is a picture of the original compressor clutch and pulley. https://ibb.co/kx62G9 Thanks for your help. |
![]() ![]() ![]() Drives: 07 5dr Join Date: Nov 2015
The 7mm bolt is left hand threaded so you need to turn it clockwise or to the right to loosen it. I've taken it off using a cordless 18V 1/4" impact, not really sure how you can stop it from spinning if you're using a ratchet.
| Zage Turbo Kit Install - Toyota Yaris | Focus_Sh1ft | Forced Induction Forum | 160 | 02-06-2022 08:14 PM |
| Valve Cover Bolt Size help. please. | 06YarisRS | DIY / Maintenance / Service | 1 | 01-02-2018 05:53 PM |
| Broken Control Arm Bolt | Sirius-XM | DIY / Maintenance / Service | 4 | 02-29-2016 08:27 PM |
| Rounded bolt replacing belt | thekatiel | DIY / Maintenance / Service | 13 | 09-29-2014 06:39 AM |
| Lower alternator bolt won't go back in, help! | Tmblackflag | DIY / Maintenance / Service | 3 | 01-21-2013 03:18 PM |
