![]() Drives: 2007 Yaris LB Join Date: Aug 2009
I love my Yaris. Its like the gray LB in the header, but is showing signs of age so I'm starting to address things - some cosmetic, some performance.
Nothing is notably wrong with it mechanically - but gas mileage isn't what it used to be. And, it seems to be less lively/spunky than when newish (bought at 11k mi). Seems a bit slow to accelerate. Are there any maintenance items that come to mind I ought to tackle to restore the little bit of pep it once had? Off the bat I'm thinking fuel filter. What else?
Keith, 2007 Yaris Liftback YouTube: Keith's Test Garage | http://www.KeithsTestGarage.com |
Knower of little
Drives: None Join Date: Jul 2019
That's a pretty simple thing to address, I'll just list it to not bore you with text haha. I don't know if the models changed depending on the country it was sold in but I don't think the USDM car has a fuel filter aside from the fuel sock in the gas tank.
Should be done
Optional to do
#3 | |
Very, very helpful. Lists are great. Thank you!
#4 | |
![]() ![]() ![]() Drives: 07 5dr Join Date: Nov 2015
#5 | |
Thanks for the input
#6 | |
![]() ![]() ![]() ![]() ![]() Drives: 2007 yaris 3 door Join Date: Sep 2015
yes. use a specific Mass Airflow Cleaner. there is a protective coating on the platinum wires and brake cleaner can damage the coating. also, i am a firm believer in BG products! i'd recommend using a can of 109 before your next oil change, maybe; you run it for 15 minutes nice and hot. drain dirty and put in some regular oil and a cheap filter. drive it around the block a few times. drain oil and install quality oil and quality filter. then BG MAF cleaner and a can of BG MOA in the oil. here is a video on the MOA...
https://www.youtube.com/watch?v=r-hUI_p4ZIU there is also videos by this guy for other gb products. (like the 109) |
Thanks for the advice. The Yaris feels great again. Here's an update!
I have several other items from your lists on the someday/maybe list. It's running well enough now that it's not at the top of my mind. Notable improvements:
Thanks!
![]() ![]() Drives: Olive yaris,FRS, Dakota R/T Join Date: Aug 2013
Biggest improvement on my 2007 Yaris sedan was a new denso OEM oxygen sensor . The one upstream. Believe it or not if has more spunk with the alternator rebuild. It has 118,500 on it.
![]() Drives: Yaris 2011 5 door Join Date: Sep 2019
For the OEM air filter, would this be the part number we're talking about? 17801-21050
| Florida Yaris Roll Call: Part 3- Post Hacking! | Sabretooth | Southeast | 81 | 05-22-2009 10:39 AM |
| Exhaust tips Sedan Liftback | tomjasz | Cosmetic Modifications (Exterior/Interior) | 25 | 08-14-2006 06:05 PM |
