Old 02-05-2020, 04:23 AM   #1
rayfloyd170
Drives: Yaris 2016 1.3 Manual
Part number and name
can you help me identify the encircled image below with its part number or give me its name? it is made of rubber covering the electrical wire from engine going inside to the body. i think it is some kind of rubber grommet but i am not sure and cannot find the part number either in the catalog.
mine was partially chewed by rats.. i did not notice it until now apart from the damaged hydraulic engine mount which i already replaced.
can this circular rubber be replaced without removing the wire harness? if not i will just put some Rubber sealant to it.
File Type: jpg Rubber Cover For Toyota Vios Yaris Sedan 2014-2016.JPG (118.2 KB, 53 views)
rayfloyd170 is offline   Reply With Quote
Old 02-05-2020, 12:48 PM   #2
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Weird, that's where the ECU normally is for US cars. My HB has a similar grommet on the driver's side going into the main distribution panel. If it's part of the wire harness, it's not a separate item and will have a bunch of sealant inside to keep water out of the cabin. You're probably better off just sealing it yourself, unless you want to pull the entire wire harness out of the engine bay.
Old 02-06-2020, 02:32 AM   #3
rayfloyd170
thank you for the reply...
that was what i am thinking of... i will just have to seal it then rather than pull out everything.
