![]() ![]() Drives: Yaris Liftback Join Date: Oct 2008
Need help with Tein spring install...
I bought a set of used Tein S-Tech springs.
I need pics of them installed from the underside. I need to find out which end is up, and I need to know what the instructions said for the recommended cut is on the bumpstops. I looked on tein's website, but the install instructions page comes up with "page not found". Thanks in advance. |
#2 | |
Break'em off some.
Drives: 07 Yaris LB, 04 Cobra Join Date: Jan 2007
Flat side of the springs go to the top, Cut the bumpstops just below the plastic piece in the center, which is cutting off about an inch. |
SOLUTION FOR BUMPSTOP CUT
OK, I got the official word from Tein on this issue.
The S-Techs require that 1.4 inches be cut off the end using their "A" cut method. They have 4 different ways to cut bumpstops, the different methods can be found in the tech section of their website.
Can't believe I'm modding a Yaris, I must really miss my STi...
Ecurie Snoopy Lives
Have fun Modding your car. And yes. I think you really are missing your STI.......
Sponsors and Organizations: Toyota Rally Canada Yokohama Tire Canada Western Canada Rally Association Ecurie (Team) Snoopy Canada, racing since 1966 ![]() |
![]() ![]() Drives: 08 silver streak mica LB Join Date: Oct 2008
i just looked at the words on the spring itself. up = up?
super duper M*******TOR
Drives: 2007 jahPANIS egg(Sarao Phil) Join Date: Oct 2008
^ if you could read the words from the spring then you're installing it correctly!
![]() ![]() ![]() Drives: 2007 and 2008 MM Yari LBs Join Date: Aug 2006
A pic of mine from a while ago.
Two Yari on home! ![]() |
| which spring is better..Tein or Tanabe DF? | seanele | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 37 | 08-09-2007 01:35 AM |
| TANABE DF210 Spring Install [pics] | Chris07LB | DIY / Maintenance / Service | 148 | 07-16-2007 09:26 PM |
| Camber after spring install | dallas | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 6 | 06-22-2007 02:57 AM |
| Tanabe NF210 spring install help | Jerkratt | Performance Modifications | 8 | 06-08-2007 10:13 AM |
