Old 12-27-2008, 12:31 AM   #1
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
Question Remote start Valet 561r install
I just bought a valet 561r from directed electronics, and I was wondering if anyone has installed this in their yaris yet? Its a 5spd '07 LB.
I will of course try to install this myself tomorrow sometime, however I was just wondering if anyone had any tips or guides to finding the correct wires, etc.
Thanks for any and all help
Old 12-27-2008, 04:02 AM   #2
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
You should have posted before you bought it and some of us might have tried to steer you clear of buying and installing such a device.I've known a few guys who have had these units installed and ended up taking them out after a short time due to electrical/techno incompatability with other components in the car.
http://www.canadiandriver.com/articles/jk/at_000515.htm
Sorry i cant be any help on the install but good luck and hope you have no problems.
Old 12-27-2008, 09:24 AM   #3
AlexNet0
AlexNet0's Avatar
What do you mean by incompatibility?
Old 12-27-2008, 10:34 AM   #4
jambo101
jambo101's Avatar
Its trying to do one thing and another component is trying to do something else.,May or may not be a problem after your install.
Old 12-27-2008, 11:29 AM   #5
Sodium Duck
╚══════════RN
Sodium Duck's Avatar
Drives: 2008 Liftback
Uhh, what are you talking about? I have a Valet 561R, and it works flawlessly.
CTScott thankfully helped install mine. Overall it was easy, as long as you understand what each wire is doing.
If you are intent on installing it yourself, then you could post up the wiring diagrams in the manual, and I could prolly remember what wires you don't need, what ones you do, and where they go. Also, Scott may have some pictures from the install that could be helpful.
I love my aftermarket remote starter/keyless entry. It rocks, and again, works flawlessly... just like the other 500 people here who have them.
Old 12-27-2008, 11:31 AM   #6
Sodium Duck
╚══════════RN
Oh, and plan on this taking a long time... especially if you're not comfortable with car electronics.
Old 12-27-2008, 02:54 PM   #7
Let me know if you have any specific questions while installing it. The 561r was an easy install.
Old 12-27-2008, 06:18 PM   #8
AlexNet0
AlexNet0's Avatar
That's reassuring, I haven't tried yet, as I was busy today helping my brother in law buld his house, however I am reasonably comfortable with wiring, car or not, I just want to make sure I do it right. The only real question that I have without actually trying yet is that: do you need to have a bypass toggle for the clutch switch, or can you just tap into the wire to the starter (well, to the ECU to send the start signal) as your "starter wire" from the unit? Or should I completely eliminate the clutch switch altogether? I dont know if having the switch permanantly "engaged" would cause any problems.
Thanks a lot
Old 12-27-2008, 07:50 PM   #9
auxmike
auxmike's Avatar
Thanks a lot
As a rule these tend to be sold as "automatic transmissions only". Bypassing the clutch switch and then leaving the car in gear ....OOPS!
BTW, Sodium Duck rocks an auto LB as do I.....
Old 12-27-2008, 09:34 PM   #10
My 09 is auto as well. There are units specifically designed for manuals or as mentioned in some other threads one can build a neutral safety switch using four springs mounted closely around the base of the shifter. The clutch switch does need to be bypassed to allow the car to start. The manual specific kits have an output that only bypasses the clutch switch in auto-start mode. To do the same with the 561r you'll need to use an auxiliary relay.
Old 12-28-2008, 01:39 AM   #11
AlexNet0
AlexNet0's Avatar
I will take pictures to document and possibly make a DIY, since I have not been able to find one so far, I have found remote lock and alarm install, but nothing that points out the correct wires for the remote start.
Old 12-28-2008, 03:19 AM   #12
AlexNet0
AlexNet0's Avatar
Couldnt find the little diagram online anywhere, even on the directed electronics website, so I re-created it (rough diagram, I know)
LINK here Or See attachment.
Old 12-29-2008, 02:26 PM   #13
AlexNet0
AlexNet0's Avatar
Well, so much for "incompatibility" lol, I have it installed, just need to add the Acc for the Climate control and its golden, works like a charm.
also, quick question, where is the relay/wire for the side lights, I didnt hook that up either. No big deal if no one gets back to me on this part, Im going to test around with my multimeter later anyway.
Old 12-29-2008, 03:10 PM   #14
Chupacabra
Drives: 2009 Yaris liftback
Sweet. Great to hear. Between Scott and Sodium you'll have the rest sorted in no time.
Chupacabra is offline   Reply With Quote
Old 12-29-2008, 02:35 PM   #15
Sodium Duck
╚══════════RN
I can pop my dash open later and tell you where everythings going if you want. Prolly around 7ish?
Old 12-29-2008, 05:47 PM   #16
AlexNet0
AlexNet0's Avatar
I believe the climate control is the green wire coming from the ignition(key).
Has there been a DIY on this yet? I haven't seen one but maybe I havent looked hard enough.
Old 12-29-2008, 07:49 PM   #17
Sodium Duck
╚══════════RN
Hmm, which wire on the unit is in question? I'll go take a look.
Old 12-30-2008, 12:00 AM   #18
White and green are both required - White is Accessory and Green is the second Ignition wire.
Northeast DIY Remote Start / Keyless Entry Workshop - Sunday, October 26 CTScott General Yaris / Vitz Discussion 51 11-10-2012 02:32 PM
Power door lock keyless entry and remote start rizaydog In Car Entertainment + Electronics (audio / video / alarm) 10 07-20-2009 05:14 PM
remote start rumor... anubisx99 In Car Entertainment + Electronics (audio / video / alarm) 11 12-28-2008 11:53 PM
Viper Remote Start goku87 In Car Entertainment + Electronics (audio / video / alarm) 4 12-13-2008 06:06 AM
warranty issues & remote start homerj In Car Entertainment + Electronics (audio / video / alarm) 14 11-27-2008 01:19 PM
