Old 08-05-2007, 06:36 PM   #1
yaris9876
Drives: yaris hatch 07 640K original m
feeding cable thru firewall
I need to feed 2 pieces of 4 awg,as thick as a little finger each, from the battery thru to the inside of the cab. I spent a
hour trying to find ANY place to get it thru. there doesnt seem to be any rubber holes except one small one in line with the passenger airbag and I dont want to use that.its too small anyway. the big bundle of wires that feeds thru that square tube is too filled up with wires to use it. Does anyone know the best way to get it thru. maybe an installer ???????
thanks....
yaris9876 is offline   Reply With Quote
Old 08-05-2007, 07:54 PM   #2
lifthard1
Drives: Black LB
Drill you a hole by the ac drain and go buy a rubber grumant and if you want put some silicone around the wires after you run them
lifthard1 is offline   Reply With Quote
Old 08-05-2007, 09:14 PM   #3
yaris9876
where is the ac drain,,link a picture if possible thanks..
Old 08-05-2007, 09:26 PM   #4
Keymaster
Drives: Yaris '06 1300cc
This isn't the AC drain but it's an idea on where to pass the cable.....
On the passengers side under the hood there is already a hole which is covered:
Inside the car on passengers side near the air-condition:
Keymaster is offline   Reply With Quote
Old 08-06-2007, 12:56 AM   #5
Vanderkitten
Vanderkitten's Avatar
Drives: 2007 Yaris Hatchback
Yeah, to the left of the ECU if you're looking at the motor there is a pass-through to left that we used for foglight wiring.
Dave V- Creator-Vanderkitten- Clothing for Women Who Kick Ass!
Many thanks to our sponsors:
Weapon-R http://weapon-r.com
Megan Racing http://www.meganracing.com
Les Schwab Tires http://www.lesschwab.com
317 graphics http://www.317graphics.com
Vanderkitten is offline   Reply With Quote
Old 08-06-2007, 02:30 AM   #6
sdmf
Down With the Sickness
sdmf's Avatar
Drives: 2007 yaris liftback
Send a message via AIM to sdmf
i went through the drivers fender and ran it through the door, works for me.
Strength - Determination - Merciless - Forever
sdmf is offline   Reply With Quote
Old 08-06-2007, 07:26 AM   #7
Black Yaris
der Zeck
Black Yaris's Avatar
that is actually very unsafe, the constant pinching of the wire in the door jamb my wear though the plastic sheeth causing it to ground out, and if you do not have it fused properly you will have a fire
Old 11-14-2008, 08:11 PM   #8
smofskra
smofskra's Avatar
Drives: 08 Flint Mica Sedan
Send a message via MSN to smofskra Send a message via Yahoo to smofskra
i also used this method and it works fine. just make sure you do NOT run it through the door hinge or you run the risk of cutting the wire when you open the door and getting a shower of sparks. (I did this in a 92 buick skylark, i speak from experience)
smofskra is offline   Reply With Quote
Old 08-06-2007, 07:14 AM   #9
punch
punch's Avatar
inside passenger foot well, pull back carpet, you'll see where the ac drain goes, i drilled right next to it ( the steel is thin)primed the bare metal, placed a grommet in and ran my wire, then silicone the whole works...
out of respect for nutzoid, I changed my avatar.
punch is offline   Reply With Quote
Old 08-06-2007, 11:20 AM   #10
ChinoCharles
Drives: LB
Someone should do a nice guide on all the nooks and crannies we can fish wire through. Possible sticky?
Old 08-06-2007, 11:33 AM   #11
Astroman
Modded Moderator
Astroman's Avatar
I was able to feed 2-6ga. cables through this hole in the firewall. I had to drill through the carpet though, but it's very concealed.
It is on the left side of the engine bay (facing the car) and is covered by a rubber stopper.
Old 11-13-2008, 03:37 AM   #12
IsLNdbOi
IsLNdbOi's Avatar
Anyone else use this location to feed a power cable into the car? Will a 4 gauge power cable fit through that and would I need to put a new rubber grommet in that would seal that hole, but still fit a 4 gauge power cable through?
Old 08-07-2007, 11:15 AM   #13
earljail
earljail's Avatar
Drives: 07 Yaris Hatch 5speed
I chose to run a 4 gauge cable underneath the car, coming up through one of the grommets in the hatch floor. The feeding of the power cable through the firewall is the thing I hate most about doing car stereo.
earljail is offline   Reply With Quote
Old 11-13-2008, 11:47 PM   #14
sportin83
Drives: 2008 blazing blue yaris LB
on my liftback there was aruber grommet behind the glovebox up high. came out on passenger side right above the pcm or ecm or bcm whatever is on the engine side of the firewall on passs side.
http://cardomain.com/ride/3151056
mods: custom sub box, i hit 141.4 db, new speakers, double-din nav, foglights, cruise, CAI, strut brace, under car braces, short antenna, remote start, alarm, actuators in doors and hatch
coming soon: window tint, custom sub grills, tach and........
sportin83 is offline   Reply With Quote
Old 11-13-2008, 11:51 PM   #15
IsLNdbOi
IsLNdbOi's Avatar
Uh yeah, that's the one pictured in the quote in the post right above yours.
So:
For anyone who has used that hole in astroman's pic. above, will a 4 gauge power cable fit through that and would I need to put a new rubber grommet in, that would seal that hole, but still fit a 4 gauge power cable through?
Old 11-14-2008, 01:27 PM   #16
sportin83
yeah 4 guage should be no problem. i ran 0 guage through and had to drill it a little bit bigger and then silicone around it.
Old 11-14-2008, 08:28 PM   #17
sportin83
the door is a bad place. i would never recomend this i have seen cars burn to the ground because of poor wire maintenance like this. always run in firewall where it will not get pinched every time you open and close the door.
Old 11-21-2008, 02:58 AM   #18
IsLNdbOi
IsLNdbOi's Avatar
Not sure if this one can be found in '08 and '07 LBs, but my 5-door '09 LB has a big rubber grommet behind the brake and gas pedals, under the carpet. My dealer routed my rear-view mirror's wire and temp. sensor through there.
Aux cable ringing yrsdrgn In Car Entertainment + Electronics (audio / video / alarm) 5 07-15-2007 09:01 PM
ipod aux cable YotaYarisUSA In Car Entertainment + Electronics (audio / video / alarm) 20 01-29-2007 01:11 AM
where to run amp positive cable??? punch In Car Entertainment + Electronics (audio / video / alarm) 8 12-21-2006 07:50 PM
using regular power lock kits with cable style twixt DIY / Maintenance / Service 4 08-12-2006 01:18 PM
Firewall!! plushDJ In Car Entertainment + Electronics (audio / video / alarm) 7 06-01-2006 12:20 AM
