Old 01-19-2009, 11:24 PM   #1
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
OMG this is why you change your OIL!
http://forums.club4ag.com/zerothread?id=19270
appalling how negligent people are
Old 01-19-2009, 11:25 PM   #2
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
i've seen it a hundred times.
5kmile oil changes for the lose
Originally Posted by xnamerxx
you nailed it sir.
Old 01-20-2009, 12:02 AM   #3
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
What in Gods name are you talking about??? Do you just randomly make shit up?
Old 01-20-2009, 12:04 AM   #4
Tamago
Tamago's Avatar
Drives: ZZW30
yes.. i'm prepping a few threads for Rockland Toyota tomorrow morning... sshhhhhhhh
but seriously.. synthetic oil gets dirty at the same rate as dino oil.. ;)
you nailed it sir.
Old 01-20-2009, 12:55 AM   #5
Snyprwlf47
The Martian
Snyprwlf47's Avatar
Drives: 07 Yaris 3dr
Send a message via AIM to Snyprwlf47 Send a message via Yahoo to Snyprwlf47
Honestly I think 5k is way too long to wait.
"The lead car is absolutely unique, except for the one behind it which is identical." – F1 commentator Murray Walker.
Snyprwlf47 is offline   Reply With Quote
Old 01-20-2009, 12:58 AM   #6
kou
Drives: 08 lb
if you want you motor to live for ever change it every 2500 miles with regular oil.
Old 01-19-2009, 11:51 PM   #7
shinlee
shinlee's Avatar
Drives: 07 liftback
are you serious?
That's the result of never changing oil, not doing it every 5k miles. I've torn about maybe 7-8 5.0 motor's on fox stangs that my family has owned, with anywhere from 60k to 150k and none have ever looked anything like that, and they did their oil changes anywhere from 5k to 10k miles.
shinlee is offline   Reply With Quote
Old 01-20-2009, 09:38 AM   #8
Bob_VT
Bob_VT's Avatar
Drives: 08 Yaris LB
4AGE 20V motors left the market in 1996....... I highly doubt anyone who posted those pictures actually owned one since new until now.
OMG the sky is falling.....the sky is falling ............
Get a grip people and start thinking things through and quit over-reacting with MUD (Made Up Drama)
Old 01-20-2009, 09:44 AM   #9
Tamago
Tamago's Avatar
Drives: ZZW30
either way it's old news, engine sludge is extremely common in new toyota engines due to lack of proper maintenance anyway.
you nailed it sir.
Old 01-20-2009, 10:58 AM   #10
nsmitchell
nsmitchell's Avatar
Drives: LB-Auto-PWR-ABS-Cruise-Springs
I change my oil when the maintenance minder light comes on. Use synthetic oil and reset your maint minder light and you are good to go. Use a good filter like Napa Gold (Wix)!
BTW - Those pics are disgusting.
Other car is a 2005 Mustang Convertible 4.0L V6 Manual - Legend Lime
Get YarAss in gear!
RIP - Casey Tatum
nsmitchell is offline   Reply With Quote
Old 01-20-2009, 07:33 PM   #11
AlexNet0
AlexNet0's Avatar
well, I guess im the only one in the world that hasnt seen one that bad before, sorry.
Old 01-21-2009, 04:20 AM   #12
GeneW
Drives: 2008 Yaris
Bought a 1982 Buick Regal with a V6. The previous owner was a hillbilly from Tennessee who was raised up before they had cars. He used horses to log.
In any case the man changed the oil every 10,000 miles whether it needed it or not. I started running Rotella through it, changing it every two thousand miles. I figured I'd slowly etch away at the crap I saw through the oil filler hole.
One day the head gasket on the driver's side failed. Doubt it had anything to do with my oil treatment, more like the car was overheated a time or two before I bought it.
When I pulled off the intake manifold and head it looked something like that motor you posted here, except it also had this black stuff that looked like coffee grounds. No biggie, I changed the gasket and was on my way.
...except...
The damn thing would, out the blue, start to get oil starved, like the oil light would come on and the lifters would chatter. This happened a lot on hills. I put up with it for a time, getting the living heck scared out of me each time it happened. We finally figured that it happened when the motor was running "hard".
One day I got inspired and took down the oil pan and found a La Brea tar pit of oil, coffee grounds, slime, wax and other crap. The oil pickup screen was two thirds clogged with coffee ground looking crap.
Apparently when I did the head gasket this crap kicked lose and drifted downwards into the pan, to clog the uptake screen.
I mucked out the oil pan, cleaned the uptake screen in carb cleaner (which will remove your skin if you're not careful) and put it all back together. Put in fresh oil.
Never had any more problems with the car until the rear body mount bolts sheared off. I sold it some kid for scrap.
The moral of the story being - change your oil!
Gene
Old 01-21-2009, 09:30 AM   #13
Bob_VT
Bob_VT's Avatar
Drives: 08 Yaris LB
The older GM V-6 was prone to oil passages clogging to do the small size. It was a common repair. Install a high volume oil pump too would help.
Inside the valve cover of ANY old engine just about looked that way. When I started rebuilding engines in the late 60's that picture was the "norm" and a clean engine was rare. Paint scrapers and kerosene cleaned them up quickly.
There were some people that would pour kerosene into the oil and let the engine run ..... this would break up the sludge and when the oil was drained it looked like syrup.
The typical "oil flush" is a kerosene based additive then drained.
History is repeating itself.
Old 01-21-2009, 01:40 PM   #14
ddongbap
Didn't you read the post?
This happens a lot with jdm motors. Since it's very expensive to keep an older car in Japan, people buy new cars with the intent of junking them at the next recertification.
Old 01-21-2009, 02:16 PM   #15
AlexNet0
AlexNet0's Avatar
of course I did, but
is what I mean, there is no upkeep of their vehicles.
DIY: CHANGE MANUAL TRANNY OIL ttufrosty DIY / Maintenance / Service 157 09-07-2018 02:43 PM
Help with oil change specs autophile DIY / Maintenance / Service 31 04-25-2011 10:22 PM
Oil change time... yay! YarisFan007 DIY / Maintenance / Service 10 09-19-2007 06:40 AM
Oil change question Ryu DIY / Maintenance / Service 22 03-08-2006 12:21 AM
