Old 11-26-2008, 11:18 AM   #1
songa
Drives: 2009 Yaris Sedan (Black)
small fingernail scratches from debadging...
hey guys, forgive me for my novice questions...but i just pulled off the toyota and yaris badges off the back of my car using fishing line and my fingernails to take off the adhesive. however, i can notice very small, shallow scratches that look like have been left from my fingernails (there may be tiny pieces of adhesive left behind too). whats the best way to get rid of these marks and make it look new again? do i use polish? wax? whats the difference? i dont believe i need to sand because these are very very small blemishes. any suggestions on how/what to do? thanks!
songa is offline   Reply With Quote
Old 11-27-2008, 12:35 AM   #2
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
If it's just surface scratches, I usually just put some carnuba wax and rub it into the scratch with a cloth. It should buff out good.
Old 11-27-2008, 09:36 AM   #3
Chupacabra
Drives: 2009 Yaris liftback
scratches can't be removed with carnuba. Use some mild compound/polish and repeat as necessary. Then cover with a sealant or carnuba.
Chupacabra is offline   Reply With Quote
Old 11-27-2008, 01:51 PM   #4
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
My bad. Yes, I used a polish - not wax.
Old 12-12-2008, 02:38 AM   #5
adamkane
Adam
adamkane's Avatar
Drives: 2006 Yaris RS
Send a message via MSN to adamkane
To truly remove a scratch you must use a cut polish, degree of cut depends on the depth and severity of the scratch, use a orbital polisher-cut compounds do not work so well when used by hand, When the scratch is removed then you will use a quality wax ie a Carnuaba based wax. Using only a wax on a minor scratch or scuff generally only hides/camouflages the blemish, when the wax wears away the scratch will again become visible.
adamkane is offline   Reply With Quote
Old 12-12-2008, 07:00 AM   #6
Tapper
Tapper's Avatar
Drives: 2008 Black RS 2dr
I always pour boiling water on the badges before removing them. It heats up the adhesive and they come off much more easily.
Tapper is offline   Reply With Quote
Old 12-12-2008, 01:59 PM   #7
texkid
The one with cheese on it
Drives: '10 Corolla S
Hmmm...now thats an idea. I just used a hair dryer and floss.
As far as the scratch, without looking at an actual picture, I use a small bead of Meguiars Scratch-x and rub. Add a little as I go until I think its enough before I strip off a good layer of clear coat and screw up the paint job all together.
texkid is offline   Reply With Quote
Old 12-14-2008, 05:18 AM   #8
I use Scratch-X, which works well for surface scratches. I remove the finger nail scratches behind the door handles from time to time. It also works wonders on the headlights.
Old 12-14-2008, 08:32 AM   #9
Chupacabra
scratch-x fills the scratches though....doesn't remove them. For that you need a cut polish.
Old 12-14-2008, 03:51 PM   #10
Yeah, I forget what the category it's in called. It takes the surrounding paint/clear coat, and blends it into the scratch.
Old 12-14-2008, 04:40 PM   #11
Chupacabra
no...it just fills it, hence the reason to wax over it or else the filler will wash out. A cut polish removes clear coat.
Old 12-14-2008, 05:25 PM   #12
hmmm, gotta buy another bottle of Scratch-X and read the back again. I thought it had said that it blends the surrounding???
Anywho, any recommendations on cut polish? I have some scratches that Scratch-X can't deal with.
Old 12-14-2008, 06:21 PM   #13
Chupacabra
There are products that work with a random orbital but for decent scratches...you will likely need to have them removed by a body shop with professional wheel/product.
Old 12-14-2008, 06:51 PM   #14
Bah. hmmm...I don't use anything except for my hands. So I have no other choice but Scratch-X????
Old 12-14-2008, 10:36 PM   #15
_S7V7N_
_S7V7N_'s Avatar
Drives: Yaris 4 Door Sedan
For the glue you can pick up some New Car Solvent / adhessive remover for automobiles, also they sell plastic razors that if used correctly won't scratch the paint. For the hairline scratches you can use some polish compound, if they're a lil deeper in there but not past the clearcoat you can mix some polish compound with some regular compound then wax over the area, Wax is recommended over any area compound or solvent is used.
Old 12-14-2008, 10:37 PM   #16
Chupacabra
nothing wrong with it....just keep some protectant on there.
Old 12-15-2008, 10:47 PM   #17
Cool. Thanks for the info.
Get your YarisWorld.com stickers! eTiMaGo Items for Sale by private party 428 03-10-2010 09:11 PM
Small science fiction story I wrote which includes the Yaris. :) john21031 Off-topic / Other Cars / Everything else Discussions 3 11-21-2008 01:57 PM
How Small Would You Go? Nigal General Yaris / Vitz Discussion 26 06-15-2007 09:44 PM
small 4ch amp. 4x100rms ben dover In Car Entertainment + Electronics (audio / video / alarm) 2 04-08-2007 05:17 PM
