Old 12-04-2008, 01:00 PM   #1
SuperFunBall
Drives: 2008 Blazing Blue 3dr LB MT
Clarion DUZ385SAT
Does anyone have one of these installed? Does it fit the double din? Happy with it or POS?
Thanks
Sometimes you have to spit on your hands, raise the black flag, and start slashing throats
SuperFunBall is offline   Reply With Quote
Old 12-05-2008, 02:04 PM   #2
SuperFunBall
bump
Old 12-16-2008, 02:52 PM   #3
MR. CANTON
Drives: Yaris Sedan
I have the CLARION VRX775VD and i had another one before that a single din touch screen. But the double din fits once you have the 2 plasic strips for the side because i have one din with the flip out screen deck and the other din has the center channel speakers for sorround sound so basically its the same screwing up as a double din deck. Fits perfect
just remember when you installing it
dont tighten the screws firm
first clip back tithe ac vents then shift the deck to fint the frame flush then tighten the deck into place,
MR. CANTON is offline   Reply With Quote
Old 12-17-2008, 12:39 PM   #4
MR. CANTON
Drives: Yaris Sedan
this is the model i sued but all double din decks fit the space.. unless u need the funisher but if u use the double din it will fit bolt for bolt ONCE YOUVE HAD THE BLACK mp3 rectangle oem deck ,, if u had the deck which is not rectangle i doubt it would work
Old 12-17-2008, 12:43 PM   #5
SuperFunBall
That is a nice setup you installed. I plan of getting the Clarion Double din mentioned above for the holiday and was just curious. Sounds like most of the DD's fit nicely. Thanks for the info.
Clarion Head Units Kaotic Lazagna In Car Entertainment + Electronics (audio / video / alarm) 3 05-15-2007 03:14 AM
clarion dxz865mp gomez1184 In Car Entertainment + Electronics (audio / video / alarm) 0 10-08-2006 11:22 PM
