![]() ![]() ![]() Drives: 2008 5 Door Liftback Auto Join Date: Oct 2011
Why my PCM try to lean the mixture at idle?
Hi All,
I've posted before about sub-par fuel mileage on my 08 liftback. I have been trying to pinpoint the issue and there's one thing in regards to that. So I hook up an obdII scanner (well it's a bluetooth adapter and Torque on an Android phone...neat) and see consistent negative long term fuel trim at idle. Most of the time it's at -7%. Under any kind of load the numbers are closer to 0. Here's a typical idle screenshot: ![]() Overall the car drives fine. The measured air fuel ratio is around 14, the commanded ratio is about the same. Things that have been done recently: - air filter - tb cleaning (had some deposits) - new spark plugs (black base ring on the original ones...rich condition? pic here: http://i425.photobucket.com/albums/p...5700548578.jpg ) New plugs are NGK iridium. - new PCV valve (oem). - reset the PCM a couple of times...fuel trim crept back to -7% pretty quick. Any ideas? Thank you.
1999 Honda Prelude Base 5 speed (summer driver) 2008 5 Door Liftback Auto |
| DIY - 1.8L 1ZZ-FE TB Connector Chip Swap | Yaris T-Sport | DIY / Maintenance / Service | 332 | 04-03-2022 02:39 AM |
| Idle Fluctuation due to aftermarket intake? | Galavoxx | Performance Modifications | 38 | 12-31-2011 09:31 AM |
| Lean Burn - Hydrogen Enrichment | GeneW | Fuel Economy Forum | 20 | 07-23-2010 03:59 PM |
| Cold Idle Speed Question... | cpnnz | DIY / Maintenance / Service | 9 | 11-04-2009 06:31 PM |
| Help with low idle from Venezuela | Yarisvene | DIY / Maintenance / Service | 5 | 06-23-2007 09:23 AM |
