Old 05-26-2009, 04:25 AM   #1
Taiyaki
アキバ製
Taiyaki's Avatar
Airbag light is on
hello,
Well after installing my power windows the airbag light is on. When installing them I did blow a few fuses and maybe did somthing?
First off what is the light mean?
and is there a way to fix it? without taking it to toyota.
Old 05-26-2009, 06:27 AM   #2
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
Be very careful when dealing with DIY fixes for airbags because if you dont know exactly what you are doing you may set it off, the resulting explosive energy could be lethal.
Old 05-26-2009, 11:21 AM   #3
saplaymate
saplaymate's Avatar
Drives: 08' HB
You may have popped a airbag wire clip out.
0 - 60 in 3 shifts
saplaymate is offline   Reply With Quote
Old 05-26-2009, 05:12 PM   #4
Taiyaki
アキバ製
Taiyaki's Avatar
so just take it to toyota?
Old 05-26-2009, 09:47 PM   #5
You can make it display the SRS DTC's by flashes of the SRS light by jumping CG to TC on the OBD connector. Power off, jump the pins, power on and watch the flashes. Count the short flashes between longer pauses and look up the DTC in the service manual.
DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 goku87 DIY / Maintenance / Service 127 02-19-2023 08:01 PM
srs / airbag light after head unit install? KwonSau In Car Entertainment + Electronics (audio / video / alarm) 7 12-24-2008 03:04 AM
DIY:Day time running light Disabled with stock fog light remain function summergxz DIY / Maintenance / Service 12 09-26-2007 11:42 AM
"Airbag" center console light on 07 Sedan with side airbags atebit In Car Entertainment + Electronics (audio / video / alarm) 5 11-10-2006 07:10 PM
