Old 02-20-2006, 11:38 AM   #1
GabL
I want JDM bumpers!
GabL's Avatar
Drives: 5 Dr Yaris RS in Blazing Blue
Shifting RPM
I just found my car won't shift from 3rd to 4th gear around 3000 rpm in some cases, I kept revving it up to 4000+ rpm THEN it shifted to 4th. Is that normal?
GabL is offline   Reply With Quote
Old 02-20-2006, 11:53 AM   #2
echo_hrs
Around the universe...
Drives: Uber-Evolved Pokemon
If the engine is cold, and hasn't reached normal operating temperature, the transmission will not shift up into 4th gear. You will find it will rev high in 3rd gear until the engine has time to warm up...
This is a normal feature on Toyotas, and somehow is set up that way to protect the engine during colder temperatures...
echo_hrs is offline   Reply With Quote
Old 02-20-2006, 01:16 PM   #3
GabL
I want JDM bumpers!
GabL's Avatar
That explains it... thanks for the info! So is it better to warm the car until the cold engine oil icon is gone before taking off?
Old 02-20-2006, 12:38 PM   #4
Ziv
It's all about VVTI
Ziv's Avatar
Drives: Yaris 5Dr LE White
funny I actually asked the same question to the dealer sometime ago, when I relize both my Yaris and my buddy Celica have the same 'Cold' icon on the display. and yeah, apparently 'overdrive' will only activate when is NOT in 'cold' such 4th gear, 5 gear depends on how many gear your car has. For auto of courze.
Ziv on Vitz '06.
Ziv is offline   Reply With Quote
Old 02-20-2006, 03:20 PM   #5
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
That makes no sense. If the engine was cold it would be better to keep the revs down, not force them to go higher.
I guess they trust the engines not to have problems revving when cold.
Old 02-20-2006, 06:12 PM   #6
swng
swng's Avatar
Drives: 06 3-dr auto RS
A possible reason for that is the car wants to heat up the catalytic converter as soon as possible so that the emissions will be cleaner. The catalytic converter cannot function with good efficiency when cold. Higher revolutions at the engine achieved by restricting upshifts to no higher than the 3rd gear can produce more hot exhausts to warm the converter up.
swng is offline   Reply With Quote
Old 02-21-2006, 10:44 AM   #7
why?
why?'s Avatar
Drives: Yaris LB
You are prolly right. That does make sense that it is emissions related.
Old 07-22-2006, 03:06 AM   #8
TRD_Yaris
Yarii Hunter
TRD_Yaris's Avatar
Drives: 2007 Yaris Liftback and S13's
and the Genius of the Day award goes to.....
Thanks for all the help over the years, YarisWorld!!!
TRD_Yaris is offline   Reply With Quote
Old 07-24-2006, 09:54 AM   #9
07WYarisRS
HardlyDangerous
07WYarisRS's Avatar
Drives: 09 Yaris LE, H/B, auto
Higher RPM's + lower gearing = less load on the engine.
running a cold engine under load is hard on it, the less load the better providing the rpm are kept the a common sence level...
07WYarisRS is offline   Reply With Quote
Old 07-29-2006, 08:03 PM   #10
paultyler_82
Drives: 07 Meteorite Metallic Yaris LB
I'm glad someone said it, thank you 07WYarisRS, please people, don't be trying to break the land speed record in third gear with a cold engine.
paultyler_82 is offline   Reply With Quote
Old 08-06-2006, 05:40 AM   #11
Katana
Katana's Avatar
Drives: Yaris LB 1.3lt 06
Anyway, I am sure that my Yaris goes better if you rev it up to 5300rpm.Always with manual transmission of course!!!
