Old 02-16-2009, 12:43 PM   #1
dobsona
Drives: Yaris, Lexus
Audible alarm when lights left on
Is it possible to either increase the volume of the alarm that sounds when the headlights are left on or to fit an auxillary buzzer by tapping into the wiring circuit, without the necessity of removing too much of the dashboard? Any help or advice would be appreciated - especially with a wiring diagram.
dobsona is offline   Reply With Quote
Old 02-16-2009, 02:32 PM   #2
wow, I suppose the easiest solution would be to find the buzzer and just swap it for a more powerful unit?
Old 02-16-2009, 02:40 PM   #3
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
the piezo is built into the gauge cluster IIRC.. you're pretty much screwed..
Originally Posted by xnamerxx
you nailed it sir.
Old 02-16-2009, 02:47 PM   #4
The buzzer is easily accessible on the back side of the PCB for the cluster. It is a 5VDC piezoelectric buzzer. You could look for a replacement one with a higher dB rating, or with a different tone that might be more noticeable by her.
Another option would be to relocate the buzzer and use a panel mount one (remove the existing and run two wires from its connection points on the PCB to the panel mount one), so the output would be directly at her, instead of buried in the cluster.
Old 02-16-2009, 03:36 PM   #5
firemachine69
School'er of hard knocks
Drives: Silver Yaris 4dr. HB
She must be really deaf. My best friend has a particularly bad case of hard of hearing (problems with tonality), and even he'll notice it AFTER he's stepped out of the car...
Tell her to pay attention to her dash when she steps out. Or don't let her drive. I've threatened the gf's driving priviledges a few times, and that straightened her out in a hurry.
firemachine69 is offline   Reply With Quote
Old 02-16-2009, 04:01 PM   #6
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
I never figured out why car mfgrs dont follow Subaru and have the lights turn off automatically when you shut the engine down.
Old 02-16-2009, 04:31 PM   #7
Tamago
Tamago's Avatar
Drives: ZZW30
most toyotas DO have that actually...
you nailed it sir.
Old 02-16-2009, 04:40 PM   #8
I sure do miss that from my Subaru Forrester.
That may actually be an easier and better fix for this issue. I have some extra automotive relays laying around to experiment with. I'll figure it out, then post a DIY...
Old 02-16-2009, 04:41 PM   #9
Tamago
Tamago's Avatar
Drives: ZZW30
you'd need a latching relay but it should be able to be done pretty easily..
that or grab the signal IN wire for the parking/headlights, and have it tie into the IGN circuit instead of the BATT circuit.
you nailed it sir.
Old 02-16-2009, 04:39 PM   #10
Forrest
Drives: 08 LB BLACK
There are people that hear pretty good but certain 'tones' do not register as loudly. You say you 'threatened your gf's driving priviledges and straightnend her out....wow..hard to believe in this day and age any woman would feel threatened.
Forrest is offline   Reply With Quote
Old 02-17-2009, 10:51 AM   #11
dobsona
Thumbs up
Thank you! I am NOT likely to be 'straightened out' as it is my car - and I am the one who always manages to find the keys when they have been mislaid...
Old 02-17-2009, 10:57 AM   #12
Tamago
Tamago's Avatar
Drives: ZZW30
so can you manage to turn off the headlights then? ;)
you nailed it sir.
Old 02-17-2009, 11:19 AM   #13
dobsona
Wink
When my 'little reminders', like the piece of pipecleaner on the doorhandle, work... but then there is always the time when someone distracts me when I am in the middle of my 'turning everything off' ritual...
Old 02-16-2009, 08:13 PM   #14
Tamago
Tamago's Avatar
Drives: ZZW30
what, mine gets deleted but his gets to stay?
you nailed it sir.
Old 02-17-2009, 11:03 AM   #15
dobsona
Thumbs down
Prejudiced or what?!! SHE set up the question
Old 02-16-2009, 05:19 PM   #16
MadMax
MadMax's Avatar
Or, get her in the habit of checking every time she leaves the car. As I run my Jeep without doors most of the time, I've disabled the alarm that tells me I've left the keys in the ignition or the lights are on. It took a little while, but you finally get used to checking them. Maybe a sticky somewhere as a reminder in the interim; but once you get used to checking every time you stop, you no longer have a problem.
And, I too am partially deaf from my military service, and I can still hear the alarm. She must be pretty deaf, how much do you yell at her?!?
Cheers! M2
Old 02-17-2009, 11:07 AM   #17
TheRealEnth
Beast
TheRealEnth's Avatar
Drives: 2007 Blz Blu LB
LMAO =D
Its a Chao!!!
Old 02-17-2009, 06:08 PM   #18
firemachine69
The only time I've ever had an issue was when I installed an aftermarket deck on my Sunfire (thus deleting any audible alarms). Did it once and learned my lesson, then did it one last time after rushing my girlfriend to the hospital.
Apparently I misunderstood the original "offender". If it's your car, you typically learn after a rather bad incident - like in minus fourty degrees weather... In any case it all revolves around PAYING ATTENTION to your surroundings. If you know you have a hearing problem, shouldn't you be more inclined to double-check visually?
Sorry, someone posting they have a very bad hearing problem, and looking for a louder buzzer, is like telling the ambulance to get a louder siren...
Question about lights kaymm General Yaris / Vitz Discussion 4 04-20-2020 10:10 PM
Keep your vehicle protected! sqcomp In Car Entertainment + Electronics (audio / video / alarm) 17 09-10-2009 03:02 AM
Dueling drivers GeneW General Yaris / Vitz Discussion 37 01-25-2009 07:32 AM
help me with my annoying alarm! misteo In Car Entertainment + Electronics (audio / video / alarm) 1 10-21-2008 02:49 PM
Smoke your own tail lights ChinoCharles Cosmetic Modifications (Exterior/Interior) 9 01-16-2007 12:00 AM
