![]() Drives: 2008 YR 5 door Join Date: Nov 2008
Proper offset?
Hey guys, i am looking at 17's for my yaris hatch, YR, The rims i am looking at are a 4x100 with a 42 offset, basically want to know if this is the correct offset for the car...
The Mach-10's http://www.tenzoracingsports.com/main.php?page=wheels |
Yup, ET42 will work just fine. Some nice wheels there. Which ones do you plan?
not 100% sure yet, but looking these 3.....
Those 3 styles are nice. I'm partial to the mesh and multispoke designs. Hmmm... I guess the mesh win out for me.
all the rims come in 17" in a 4x100 configuration with a 42 offset, won't fit?
Yes. 17x7, ET42, 4on100 will do just fine. Run 205/45/17 on stock suspension or with a mild drop.
on stock suspension or with a little bit of camber, you can easily run a +35 offset.. it'll give you a very nice flush look. 205 tire MAX though.
#8 | |
l33t3st Asshole
Drives: MY07 Yaris Liftback Join Date: Nov 2006
EDIT: why did you choose tenzo if you don't mind me asking? |
#9 | |
der Zeck
I run 17x7 +18 front and +5 rear.... with 205/40R17.... I am lowered 3 inches, no rubbing problems.
#10 | |
l33t3st Asshole
does the OP? ![]() I run a 15x7 +35mm on my YARIS and it rubbed when lowered until we put coilovers on. I have a feeling that's a little more applicable then your scion when regarding the OP's setup. Although I could be wrong.... |
#11 | |
Small cars are a big deal
Drives: 2007 Yaris Liftback Join Date: Feb 2006
Yaris + Low offsets = Rub. I rubbed with a 15x6.5, +38, and 205/50/15s I rubbed badly with a 16x7, +37, and 205/50/16s Heck, I even rub a tad bit with +40 and 195/55/15. Granted, my front end is pretty low, but not that low.
Subcompact Culture: The Small car blog |
#12 | |
i recommend Team Dynamics (the racing line, not the "street line") an excellent UK-made wheel and comes in decent offerings for width and offset. simple designs, strong, and relatively lightweight
der Zeck
well you were commenting to Tamago.... also a Scion owner
l33t3st Asshole
who was commenting about the OP. come on, I know you're smart enough to realize what's happening here.
Main reason I replied to Tamago is b/c HE KNOWS the +35mm will rub when lowered (he was there when we rubbed the first time with our +35mm). he also knows that a +23mm 15x7 doesn't rub on stock height but pokes a good amount on a YARIS (they were his wheels we used to test). I wasn't trying to say he's wrong, b/c he isn't. He simply left out a small portion. :) |
i believe he was commenting on my comment about running a +35 on a yaris.
i personally run +23 front +(13) rear
I'll have to say the Yaris is definitely the fussiest car I've owned with regards to offsets and lowering.
To avoid rubbing problems with 205's, go with ET42 or higher.
Of course, on stock suspension you can run lower offsets... but the front set-up will poke and look like shit. Like 39 says, this is a very fussy car for proper fitment. But, if you want the one-size fits-all American look, then go for it. |
| Offset and lowering on 205/45/16s | driver centric | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 22 | 08-13-2016 11:09 AM |
| How to determine proper wheel offset? | Yaris Revenge | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 14 | 05-23-2009 11:41 AM |
| offset... | Keymaster | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 4 | 02-01-2007 02:53 AM |
| max width and offset? | Fat Felixxx | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 2 | 06-08-2006 04:43 PM |
| Max offset | riceboy | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 9 | 05-01-2006 10:57 PM |
