Old 02-03-2009, 11:38 PM   #1
escotric
escotric's Avatar
Drives: Toyota Yaris
computer problem
I had my dell Desktop sitting collecting dust for a while and took out the hard drive and put it in an usb external exclosure and noticed that some of my files werent showing up on my Rig. The hard drive properties showed that it was using 60 gigs of data and inside the hard drive folder there was only 20 gigs. So that leads to wheres my 40 gigs? Unusual. Help!
escotric is offline   Reply With Quote
Old 02-03-2009, 11:47 PM   #2
Phaeton
Phaeton's Avatar
Drives: Blazing Blue Liftback
Try this http://www.annoyances.org/exec/show/tweakui
Old 02-03-2009, 11:55 PM   #3
escotric
escotric's Avatar
Originally Posted by Phaeton View Post
HELP!!!!
Old 02-04-2009, 12:29 AM   #4
TheRealEnth
Beast
TheRealEnth's Avatar
Drives: 2007 Blz Blu LB
or if you dont care much for what those 40 gigs could be just reformat it>?
Its a Chao!!!
Old 02-04-2009, 01:39 AM   #5
Malaya1221
super duper M*******TOR
Malaya1221's Avatar
u might be doing something wrong...the second image is just a folder's properties not the j: drive properties that is why u r only getting 20 gb of files!
is the second image the main folder to the j: drive?
Old 02-04-2009, 02:05 AM   #6
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
Start -> Control Panel -> Administrative Tools -> Computer Management. Expand Storage in left pane select Disk Management. Check to see if the drive is partitioned.
Old 02-04-2009, 09:43 AM   #7
SailDesign
Drives: .
Hopefully a silly question, but.... Is the USB encloseure size-limited? Some of the cheaper ones are "old tech" that may not be able to recognize a drive bigger than 20Gb
Old 02-04-2009, 11:34 AM   #8
IllusionX
Drives: 07 Yaris Sedan Aero
Most likely to be hidden files and folders.
Old 02-04-2009, 11:37 AM   #9
40 gigs of porn!
Seriously, here's a good program you can try to use to see what's in there:
windirstat.info
Old 02-04-2009, 11:55 AM   #10
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
get service pack 2 for windows...from what i ran into service pack 1 limit reading the whole hd.
Old 02-04-2009, 05:52 PM   #11
IllusionX
sp1 is limited to 128gb.
old usb enclosure MIGHT be limited to 160gb.
but if the partition was created before, then it will have no problems accessing it.
steering problem redgreen DIY / Maintenance / Service 31 09-18-2015 09:20 PM
Service Problem Lizardboy DIY / Maintenance / Service 19 10-06-2006 10:12 PM
