![]() ![]() Drives: 5spd 2007 Yaris LB Join Date: Jul 2007
1st gear
okay well anyways, whenever i drive my car sometimes (like maybe about 30% of the time) when i'm trying to shift back into first (coming from nuetral or 2nd or w/e) its really hard to get back into first, like theres something blocking the way. does anyone else have this problem as well? i eventually get past it by just pushing a lil harder so i didn't pay any attention to it but one day when i was driving with the windows down and the music off i noticed it made a very faint whirring sound whenever it got stuck like that and i tried to push it a lil harder.
i have no idea, it doesn't sound bad or anything, it doesn't sound like a gear getting grinded but the thing about this problem is other times shifting back into 1st is like butter, its so smooth. so i have no idea whats going on, i'm just worried if it might become a problem later on any input?
99.9% of what goes on in my mind at work/school/home ![]() [Debadged] [Tanabe DF210] [Limo Tint][17" Fondmetal Wheels] [Pioneer HU] --:: Wishlist, PM me ::-- [SSK (WTB)] [Black Sand Pearl Eyelids (WTB)] |
der Zeck
you must be a noob to driving stick shifts, because most manual trannys are like that to prevent you from shifting into 1st at too high of a speed and over reving your motor
![]() ![]() Drives: Yaris LB Join Date: May 2007
Yeah, typically I never downshift into 1st gear; sometimes I'll come to a near stop and then put it into 1st, but never to help me stop. At first I did have a problem downshifting into 2nd because you have to push it back over; my Subaru doesn't require this, so I kept downshifting from 3rd into 4th instead of 3rd into 2nd. Good luck.
#4 | |
![]() ![]() ![]() Drives: '07 Blazing Blue LB, '09 Jetta Join Date: May 2007
to me, i let the brake do all the job and a quick shift to neutral before the brake.
current: '07 Yaris LB - '09 VW Jetta ex: '06 Beetle S(19x8.5 Audi A8) - MK4 GLi BMP(18x8 OZ, K04) - '03 GTi(17x7.5 Ronal, APR93) - '01 GLS - '88 GTi - '86 GTi - '83 GTi |
#5 | |
Lurker supreme!
But ya, typically you don't engine brake into 1st gear since you're pretty much stopped at that point.
2006 Red Blitzed RS 5-door |
#6 | |
![]() ![]() ![]() Drives: None Join Date: Mar 2007
#2: This is perfectly fine, just stay in gear until your revs drop really low (idle range), then clutch in and brake. |
Roar?
release the clutch and then press the clutch the syncros arent ligned up... first isnt syncronized so its what black yaris said about over-revving
#8 | |
By releasing the clutch in neutral first, you get the layshaft to a similar speed to the output shaft, meaning the syncro's job is easier. Do completely rev match, you must blip the throttle when you are in neutral, then clutch in and go back to first. This shouldn't be necessary though. Just make sure you are SLOW to go into first, be gentle and you won't wear your syncro. |
![]() ![]() Drives: '07 YR 3dr Join Date: Jul 2007
It's probably something designed into the sycro's on 1st. You'll find you have no problems/resistance when it it stopped or at walking pace. It's so you don't get 1st instead of 3rd liek others have mentioned. I had the same on my '68 VW. It'll go in, you just have to use a little more force (like on a dog-box) ;)
"I drive a silver egg" "Huh?" "An egg... You know; pretty much round, but with a pointy end; jeez..." |
Lurker supreme!
If I'm doing a fast rolling stop and I want to drop it back into 1st, when I take my foot off the brake I'll blip the gas pedal -- give it a quick stab to bring the revs up -- and it helps shift into 1st eaiser. A bit of rev-matching never hurts!
ahhh gotcha, yea this is my first manual car so i didn't know bout that ;] i guess i see it now, cause when i brake while holding in the clutch i put it in first (thinking ahead i guess when i know i'll be coming to a stop then having to go) but now that you come to mention it, the times it does give me no trouble at all are when i'm either stopped or slow.
lol
![]() ![]() ![]() Drives: 07' Yaris Liftback - silver Join Date: May 2006
well i'm never downshifting into first while braking, i'm talking about how i shift it back into neutral, apply the brake and try to switch it to first while i'm slowing down (clutch still pressed) cause i know i'm going to need to stop and go (ie: stop signs)
46 and 2, just ahead...
Drives: 07 Yaris sedan Join Date: Jun 2007
It just seems that it costs a lot less to replace the brake pads than it does to replace a clutch..so why not just use the brakes, as they were designed, and leave it in neutral until you stop? Not seeing the advantage to the extra wear n tear...
![]() ![]() ![]() Drives: 03 Toyota Corolla S modded, Join Date: Jan 2007
Just put it on neutral, your not Auto-X'ing..
THE YARIS: TINY BUT PRICEY! BUT YOU JUST GOTTA LOVE IT....
![]() ![]() ![]() ![]() ![]() Drives: 2007 Bayou Blue!!!!!!! Join Date: Nov 2006
in 20 yrs driving stick, never geared down into first!!!!
Sometimes instead of stopping dead and wasting momentum coming into a red light, I'll slow to 5 MPH or so and shift into first and apply enough gas to get into gear, then apply no gas. Try it and the car just crawls forward at idle. Light turns green and you just skipped a dead start in first. Yes, I'm this lazy.
#18 | |
| Vitz (1st Gen) Tid Bits | Airknight | General Yaris / Vitz Discussion | 1 | 03-09-2017 04:24 AM |
| Vitz (1st Gen) Tid Bits | Airknight | DIY / Maintenance / Service | 0 | 06-25-2007 05:12 AM |
| speedo gear | AlanSRT4 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 04-27-2007 10:37 AM |
| Which Redline gear oil is the best for our Yaris? | stevencyt | DIY / Maintenance / Service | 0 | 03-13-2007 11:11 PM |
| clicking into first gear | tekmoe | General Yaris / Vitz Discussion | 9 | 11-01-2006 02:44 AM |
