Old 09-11-2006, 11:34 PM   #1
casterqc
Drives: Yaris
Rust Protection
I've decided to start a new thread on rust protection, for those like me who have to deal with the snow...and the others who simply care.
I know there is already a thread on this but it ended up debating if rust protection was good or not.
Please lets only make this thread a good source of information for people that want to choose a good rust protection product.
Personnaly I never used any rust protection on my cars...and ended up dealing with surface corrosion and also perforation...don't want this to happen to my new car!
I know there is oil treatment you can put every year.
There is the wax treatment you can put every 2-3 years.
And also, new to me, the electronic device you can install for 200$can that protects your car from rust (like Counteract)
Have you ever use one of these products? What are your pro's and con's?
casterqc is offline   Reply With Quote
Old 09-12-2006, 12:17 AM   #2
07WYarisRS
HardlyDangerous
07WYarisRS's Avatar
My parents have the electronic box on their 2002 Buick regal GS 3800 S/C, but this past summer I had to snadblast and repaint the rear fenders due to rust and paint peeling. IMO the box is worthless, but I know other that swear by it.
I won't take my car in ever again to be oil sprayed or rust proofed
I'll do it myself until I'm too old and unable, so i know it's done properly.
Two of my cars I have had done by several shops and every time they did a half assed job. When i got home I pulled the inspection/oil plugs only to find they were never sprayed, and the oil they use is so light it does not seem to stay on after a few months. I believe it's gear oil.The one shop that did not use oil used a heavy, sticky foamy type stuff and it made a mess of everything and migrated into the inner door jams and was a pain to keep clean and maintain. Nasty stuff but it seemed to work where it was sprayed (again lots of missed areas)
For my cars/trucks I have been rust proofing them myself for several years with AWESOME results. I have not done the Yaris yet but have a couple cans ready to go.
Here's what I do (It's easy but takes an hour or two)
I buy a few cans of Rust Check from Canadian Tire. For the yaris only two LOL
Normally I use 2-3 cans of the Rust check rust inhibitor (red can), and one can of coat and protect (green can)
Then I go to the dollar store and buy a cheap tarp or two (if they are the small ones) and park the car on it to protect the driveway from oil drips.
I start by doing the obvious things like removing door pannels and spraying down inside the bottom edges with the rust inhibitor, same with the tailgate/hatch doors. It's a migrating oil so keep that in mind. (don't spray near the glass) if you don't want to pull off the pannels use the straw and spray in the water drain holes in the bottom of the doors.
Then I remove the tailights, marker lights and headlights and spray down the inner fenders.
Most cars you need to remove an inner pannel or two to get at the inner fenders in front of the rear wheels and under the carpet along the rockers to get at the plugs.
Spray it in every possible spot.
A few cars did not have plugs in the rockers so I drilled my own and bought the plugs to cap them when i was done.
Pop the hood and spray down inside the inner fenders and lower body lips, bumper struts/supports etc. I even spray inside the hood edges etc.
Get under the car and spray down the fuel tank, sending unit and back side of the fill hose/through the body
The Coat and protect I spray heavily on the fuel tank seams, fuel lines, filter and sending unit after the rust inhibitor. I also spray suspension components, axles and brake lines etc.
Once that is all done I use a wagner electric paint sprayer and lightly spray the under side of the car with cheap ATF or light gear oil.
Sure there is better stuff out there but my fathers 56 lancer had an oil leak since 1958 and the under side of the car looked like new so i know ATF works to protect it.
Anyway I spray down the under side of the car around everything except the exhaust/engine with oil
The last step is optional but helps
Find a dusty dirt road if you have one close by, then tear up and down it a few times.
I usually do this every fall, but be prepared to wash you car often for the first couple weeks. The oil will settle and run out of seem just like with any oil spray job.
Old 09-13-2006, 05:51 PM   #3
casterqc
Drives: Yaris
That is some good information 07WYarisRS! Thanks
I don't know if I have the same patience you have to do that each year tho...
So far the only thing I'll be doing myself for rust protection is painting the drums and calipers each year and wax the car at least twice a year.
I have a friend that worked at a car dealer and his car was treated with the "wax protection"...never had any rust on the car...and it doesn't leak like oil do. But I agree with you, maybe 85% of the places that offer anti-rust service don't do it well...so it is always better to do it yourself if you have the time and knowledge.
Old 09-13-2006, 08:30 PM   #4
ketel0ne
ketel0ne's Avatar
Drives: 2007 Liftback Blazing Blue
Here's some volvo dealer stock spray.
http://cgi.ebay.com/ebaymotors/VOLVO...spagenameZWD1V
ketel0ne is offline   Reply With Quote
Old 09-13-2006, 09:56 PM   #5
07WYarisRS
HardlyDangerous
07WYarisRS's Avatar
A person could skip the paint sprayer step and just go crazy with a few cans of rust check and still get great protection and save a fair bit of time and $$$ doing it yourself.
To have a shop spray may car cost $100, I can do it for less then 1/2 that at home.
Old 09-20-2010, 05:11 PM   #6
sleey0
Drives: 2008 Yaris LB
I say just wash your car weekly or as much as u can during the winter.
I have yet to see anything really work well to protect a car unless you take all panels off and coat with a ceramic type spray.
sleey0 is offline   Reply With Quote
Old 09-20-2010, 09:44 PM   #7
sleey0
I didn't even look lol/
Someone hit me with a n00b-hammer plz! l2ms
Old 09-20-2010, 10:49 PM   #8
JumpmanYaris
USAF_SrA_E-4
JumpmanYaris's Avatar
Drives: C300 / Del Sol
n00b
Originally Posted by sw07gt
Old 09-20-2010, 11:09 PM   #9
sleey0
Yup yup!
LOL
I just ordered some waxoyl. This thread got me thinking so I figured I'll try it out since I found it and it wasn't expensive.
So, in a wierd sense, THANK YOU to that spammer for resurecting the dead hahaha.
3M Trim-line Pain Protection? GD-RS General Yaris / Vitz Discussion 12 04-11-2006 10:46 AM
Protection!!!! ricko DIY / Maintenance / Service 16 04-10-2006 12:29 PM
Toyotaguard Plus Protection Group-XY70 YotaYarisUSA General Yaris / Vitz Discussion 3 04-03-2006 08:57 PM
