Old 02-23-2009, 02:25 PM   #1
tomato
tomato's Avatar
Is it me or does the Yaris have a touchy clutch?
Is anybody else having the same problem?
I just got my car (Yaris LB 2007 manual transmission) a couple of weeks ago and I'm having a really hard time shifting gears smoothly. The first gear is especially touchy!!
I only drive it around for errands and stuff, not on a daily basis, so it is possible that I'm still in the transition phase of adapting to a different car? I have been driving Hondas manual transmissions for a lot of years, and they do feel a little different (easier, I think).
I did not purchase the car new, but I've had clutches go out on me before, and it doesn't feel like that is the case.
I've read somewhere in the forum that other posters have had that same problem in the beginning. How long did it take you to get through this "transition" phase, if that's what it is? Right now, it's really unpleasant, almost feels like I'm learning how to drive again.
Can anything be done to adjust the clutch? Should I have it checked, just in case?
Any ideas, suggestions, would be greatly appreciated. Thanks!
Old 02-23-2009, 02:31 PM   #2
BLAZINBLUEVITZ
BLAZINBLUEVITZ's Avatar
Drives: 2007 YARIS 3DOOR
NST crank pulley cured my 1st gear stalls.....
Old 02-23-2009, 02:32 PM   #3
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
I didn't have any real problems when I got mine - other than adjusting to a light clutch pedal (the spring doesn't have much resistance) it shifts just fine.
Perhaps you can elaborate on the issue. Are you grinding? Is it just hard to get into gear? What symptoms other than being 'touchy'...
Old 02-23-2009, 03:04 PM   #4
tomato
tomato's Avatar
Ah, yes, sorry about that.
It's not grinding. It's really hard to explain...
It seems like I have to put a lot of weight on the left pedal to shift gears smoothly otherwise I can't shift gears. So, when I think I'm pushing on the pedal all the way, I'm really not, I might be missing 1/2 a centimeter or so, but it's enough to make the car stall.
Come to think of it, it can happen also when I downshift. Frustrating
Old 02-23-2009, 02:34 PM   #5
id3379
§†ęĄ¶‡Ћ-NCP96
id3379's Avatar
i have no problem with the clutch, and ive had 4 and 6 puck clutches on my old Honda's before, i think the clutch is perfectly fine.
only gripe is the slow electronic throttle.
id3379 is offline   Reply With Quote
Old 02-23-2009, 03:22 PM   #6
MUSKOKA800
MUSKOKA800's Avatar
TRD axle back cured my touchy clutch. Now that I can hear the engine it's much easier to feather the engagement.
Old 02-23-2009, 03:25 PM   #7
YarisSedan
Drives: 08 Yaris Sedan
There is a beakin period since the flywheel is still fresh. Just like there is a breakin period when you do a break job when the rotor is new or freshly resurfaced. So it will feel little different as you start to drive it more. Also you could be used to driving a clutch thats already worn compared to a new one. Every car is going to ahve a different point where the clutch engages.
When i first learned to drive i was taugh to not touch the gas. Remove the clutch pedal til you can feel the point of engagement then let go and whala the car is moving on its on with you revving the gas while letting go of the clutch. Which is a good way to wear out your clutch fast.
That is the only real way to get a good feel of your clutch. Eventually you will have that point memorized and then you can time your shifts precisely.
Old 02-23-2009, 03:26 PM   #8
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
Yes, the clutch is weird in the Yaris. It has a very long throw and a very soft touch. It begins to grab VERY low on the pedal, but doesn't fully release until very near the top. It takes some getting used to, as does the electronic throttle and the fact that you can't really hear the engine.
You'll get used to it.
Old 02-23-2009, 03:35 PM   #9
YarisSedan
After awile you will think that what you feel is normal and other cars are the ones that have problems. Whenever i drive my acura from time to time i hate how the gas pedal feels kinda hard when pressing down and how the steering is so stiff.
I have become acustome to drive by wire and electric steering dare i say it!
Old 02-23-2009, 03:57 PM   #10
33OH
Drives: '08 Yaris
+1
Old 02-23-2009, 04:23 PM   #11
IllusionX
Drives: 07 Yaris Sedan Aero
it's all been said by others already i guess... the clutch is perfectly fine. It's the slow response DBW the problem.
talking about a light clutch, if you guys have not driven the new hondas, you don't know what is really a light clutch.
You don't need to push a Honda's clutch very far to shift or start up from 1st.. hmm.. not the case with toyotas.
Old 02-23-2009, 04:28 PM   #12
tomato
tomato's Avatar
Got it. I had no problem with the FIT or the other Honda's I've had in the past, but this is my first Toyotal. I guess they're just adjusted a little differently, uh?
Excuse me but what's "DBW" ?
Old 02-23-2009, 04:35 PM   #13
TheRealEnth
Beast
TheRealEnth's Avatar
Drives: 2007 Blz Blu LB
i think Drive By Wire o.0 or... maybe dont bother with
Its a Chao!!!
Old 02-23-2009, 09:16 PM   #14
tomato
tomato's Avatar
Thanks, everybody.
Old 02-23-2009, 09:20 PM   #15
blktiger60
blktiger60's Avatar
Drives: `08 HB S
Ya, you'll get used to it.
I can smoke the stock tires in first and get a good chirp outa second now that I'm used to it.
- The Black Ship Yaris -
blktiger60 is offline   Reply With Quote
Old 02-23-2009, 09:26 PM   #16
KSIbucky
KSIbucky's Avatar
Drives: 2007 Yaris manual dark silver
Send a message via AIM to KSIbucky Send a message via MSN to KSIbucky
my car sometimes downshifting into 2nd i hate it
7 Color Tach
Fujita Intake
Momo pedals Shift knob and boot. Full TRD SSK.
Blitz exhaust
Megan Lowering Springs
(Next is DC Header)
KSIbucky is offline   Reply With Quote
Old 02-23-2009, 09:33 PM   #17
tomato
tomato's Avatar
I know just how you feel!
Old 02-23-2009, 09:33 PM   #18
Forrest
Drives: 08 LB BLACK
Touchy clutch with the electronic acceleration. Takes a bit getting used to.
Forrest is offline   Reply With Quote
Fuel Economy swng Fuel Economy Forum 2089 01-23-2015 07:41 PM
Interesting Info on the Yaris from AU mikeukrainetz General Yaris / Vitz Discussion 3 11-24-2006 10:18 PM
