Old 02-19-2009, 07:01 PM   #1
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
Ehh so
..... i got the NST UD pulley today and well tried to install it and omgwtfpwnz i cant get the bolt off. my impact gun is a 1/2 drive so i couldnt get a good grip
on it to cover the bolt with the socket. I manage some how to get it in a little slanted and a little grip. That didnt work. I am working with a 250 tq electric gun. Any suggestions???
By the way thats the only gun i could get.
Yoda is offline   Reply With Quote
Old 02-19-2009, 07:04 PM   #2
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
bigger gun with a big compressor!
Old 02-19-2009, 07:08 PM   #3
Yoda
Yoda's Avatar
Its electric and i not gonna go get another one then go buy a compressor for $$$.About to have a mech do it.... is the like a extension for the gun?
Old 02-20-2009, 12:13 AM   #4
turboyaris
Drives: 2007 Yaris Sedan
Send a message via AIM to turboyaris
put the car in gear, and get a breaker bar
turboyaris is offline   Reply With Quote
Old 02-20-2009, 12:25 AM   #5
jkuchta
Drives: 2007 Yaris hatch (red)
^+1....That's how I'm going to get 'er done on Monday at Microimage.
$10 breaker bar at harbor freight can "fix" anything.
jkuchta is offline   Reply With Quote
Old 02-20-2009, 01:39 AM   #6
TOUGEghost
Mr. Clean
TOUGEghost's Avatar
Drives: 2009 Yaris S 3-Door
You should be able to use a short extension for the impact if you can't get it to fit directly on the bolt. Putting the car in gear and using a breaker bar is a pretty abusive way to do it (if that even works). There's another way to do it with a breaker bar, but I don't think anyone who knows wants to give up the secret due to liability reasons.
Old 02-20-2009, 03:40 AM   #7
insane mechanics when I got mine installed could not loosen it by hand either... so one guy held on the breaker bar real strong while the other cranked the engine for a split second... Worked like a charm! Though be careful if you try this, you probably don't want to clean up pieces of shredded appendages from your engine bay...
Old 02-20-2009, 06:21 AM   #8
TOUGEghost
Mr. Clean
TOUGEghost's Avatar
I should have known someone out there knew an even worse way to do it.
Old 02-20-2009, 05:25 AM   #9
CtrlAltDefeat
I ♥ Yaris
CtrlAltDefeat's Avatar
I was able to get it loose with just a breaker bar and a rubber strap wrench... cranking the engine with the breaker bar on the the nut is insanely dangerous... you could hurt yourself and/or the car.. I would NOT recommend it...
Old 02-20-2009, 05:29 AM   #10
CtrlAltDefeat
I ♥ Yaris
In case you're wondering I wrapped the strap wrench around the pulley, and braced it against the chassis so I didn't have to hold it, and just cranked real hard on the breaker bar... If you think you might have problems with that, get a pipe to go over the end to lengthen it so you can get more leverage... as Archimedes said, “Give me a lever long enough, and a prop strong enough, I can single-handed move the world.”
Old 02-20-2009, 10:15 AM   #11
at3GG
at3GG's Avatar
Drives: 07 metmet LB
heh notice he never said it was a good way are necessarily recommended it. You can get a tire back on the rim by spraying combustibles inside it then lighting a match, but why the hell would you actually try it?
F5 CAI, MR axleback, MR Header, NST SSK.
Full Exhaust wrap, AT3 Custom SSK
Konig Heliums 15x6.5 Black
Tanabe Df210's
at3GG is offline   Reply With Quote
Old 02-20-2009, 11:55 AM   #12
Yoda
Yoda's Avatar
i gonna see if i can get an extension for the gun when i get off work and try it one more time if not then i see if i can find a breaker bar somewhere...
Old 02-20-2009, 12:24 PM   #13
jkuchta
TOUGEghost,
You're telling me putting the car in gear and applying the brakes (to keep the engine from spinning), and then using a 30" long breaker bar with a fully seated socket is abusive?
Explain.
Old 02-20-2009, 03:54 PM   #14
Yoda
Yoda's Avatar
got some more tools gonna give it another try
Old 02-20-2009, 04:19 PM   #15
jkuchta
Were all behind you Yoda
Old 02-20-2009, 04:37 PM   #16
Yoda
Yoda's Avatar
ok i got the bolt off not too bad just needed an extender and some back bone... now new prob i put the alternator bact to the positioned i marked it at but the belt still feels loose
so i tried making it a little tighter and started the engine....it squeals really loud help me plz -_-'
Old 02-20-2009, 05:08 PM   #17
Yoda
Yoda's Avatar
so i put it in the stock position again turned the car on and you kno what only the pulley spins its just spining there with the belt on it.
i am thinking there is a sweet spot somewhere
Old 02-20-2009, 05:45 PM   #18
supmet
Drives: 2007 4 Door Yaris
sounds like the belt isn't tight enough... if its tight, the belt pretty much HAS to move with the pulley.
