Old 07-10-2009, 01:51 PM   #1
mojoyaris
Ecurie Snoopy Lives
mojoyaris's Avatar
Drives: Jojo
overheating, fuel cutout issues?
Does anybody have any overheating or fuel cutout issues?
Sponsors and Organizations:
Toyota Rally Canada
Yokohama Tire Canada
Western Canada Rally Association
Ecurie (Team) Snoopy Canada, racing since 1966
mojoyaris is offline   Reply With Quote
Old 07-20-2009, 02:47 PM   #2
Tamago
Tamago's Avatar
Drives: UZJ100
can you be more specific ?
Old 07-20-2009, 03:17 PM   #3
supmet
Drives: 2007 4 Door Yaris
Does it overheat and then the fuel cuts off, or do they happen completely separate of one another.
Old 07-21-2009, 04:49 AM   #4
anonymous user
rarer than JDM -1 of 1!
anonymous user's Avatar
Drives: 07yaris
I'm guessing separate events? Explain more of the fuel cutoff issue, or were you asking a Q. in general?
It's not what you drive, or how much $$ you throw at the car. Mod the ballast on the front left first!
anonymous user is offline   Reply With Quote
Old 07-26-2009, 02:31 PM   #5
toyota
SRacer
toyota's Avatar
Drives: Toyota Yaris 2007
Send a message via Yahoo to toyota
yeah be a little more specific
so we can help...
"If I go down, I do time. I do real time. I don't know about your other drivers but when I see flashing lights in the mirror I don't stop."
- Dominic, Fast & Furious
Learn The Truth about Six Pack Fast!
toyota is offline   Reply With Quote
Old 07-29-2009, 12:44 AM   #6
mojoyaris
Ecurie Snoopy Lives
mojoyaris's Avatar
Drives: Jojo
Been away for awhile.
The car runs between 4500 rpm and 6700 rpm constantly at the track.
With the stock thermostat it over heats after a 15 minute hard run on the track and since the car runs lean, it seems to not get enough fuel.
I installed the TRD thermostat and better radiator cap for pressure and although it doesn't overheat, it will cut out when running the car hard, turning the car hard etc.
Basically if I run it 8/10's to 9/10 speed this way it will cut off the fuel or there is fuel starvation.
When I let off the throttle and drive it slowly, it will go back to normal and I can run again, but not for long. I basically have to give it a cool down lap before running hard, but this can be a problem when I'm timing a lap or something.
On day to day driving there is no problem. Only when driving at a Solo 1, time attack or track day. Especially on smaller tighter courses where I'm doing hard 2 to 3rd gear shifts.
I've got a few months to figure this out before I decide to enter the car in the Targa or not.
I'm thinking about getting bigger fuel pump. redo the air fuel management mapping
and bigger/better injectors.
Toyota Rally Canada
Old 07-29-2009, 01:07 PM   #7
Tamago
Tamago's Avatar
Drives: UZJ100
you don't need any of that stuff.
buy a MAF translator and just tweak the MAF signal to trick the ECU into giving you a few percents more fuel at your target RPM.
http://www.horsepowerfreaks.com/part...rs/Gen_2/15418
Old 07-29-2009, 01:18 PM   #8
Biggie™
Biggie™'s Avatar
Drives: '07 3 Door Yaris of Doom!
Too bad the Yaris ECU will learn around that in about 5 minutes and render it useless...
Biggie™ is offline   Reply With Quote
Old 07-29-2009, 01:20 PM   #9
Tamago
Tamago's Avatar
Drives: UZJ100
.. not if you know what you're doing ;)
Old 07-29-2009, 01:24 PM   #10
Biggie™
Biggie™'s Avatar
Um, no... More to the point that fuel is obviously not his problem, but whatever.
Old 08-07-2009, 05:30 PM   #11
CpKi1g3
High speeds are fun...
CpKi1g3's Avatar
Drives: 07' Polar White sedan Base
Send a message via MSN to CpKi1g3 Send a message via Yahoo to CpKi1g3
just take off the thermostat my friend did it on his supra and ran much cooler.
CpKi1g3 is offline   Reply With Quote
Old 08-16-2009, 01:17 PM   #12
mojoyaris
Ecurie Snoopy Lives
mojoyaris's Avatar
Drives: Jojo
Overheating is not the issue anymore. Not with the TRD thermostat.
It's the fuel cutout. This should be fixed later on.
Thanks everyone for their input.
Toyota Rally Canada
Old 07-29-2009, 12:54 PM   #13
Biggie™
Biggie™'s Avatar
I've done several(8-10) track days in my Yaris, some were on hot summer 103ş days with track temps in the 130s... And I've never overheated the Yaris, nor had any fueling issues.
The overheating might be causing the ECU to go into limp mode, cutting power and giving the appearance of "fuel cut". Have you ever had your "fuel cut" problem when the car wasn't over heating?
I'd suggest replacing your aftermarket bumper with the stock unit and run another hard track day, there is a good possibility that the ducting/airflow is not as efficient as the OEM bumper. If less air is going through the radiator less heat will get whisked away.
And if that doesn't help, I've had good success cooling down overheating race cars with the addition of a well placed oil cooler.
Old 07-29-2009, 01:37 PM   #14
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
It is stated that the car is overheating. How do you know that? What is the actual temperature? Is the ECU storing any fault codes?
The only time I got any behavior of that sort from my car, it was due to a bad spark plug causing misfires at very high revs. (banging the rev limiter in 3rd coming out of turn 17 at Sebring) In my case, it would sometimes toss a misfire code, and a couple times it must have been so bad that the ECU just shut down and went into limp mode until I restarted the engine.
A new set of standard (non-unobtanium) NGK plugs fixed that problem.
So, be certain of what you're dealing with. If the car IS overheating, then fixing the fuel system surely isn't going to cure THAT problem.
You didn't mention what mods you have on the car. It seams reasonable to assume that you're turbo or supercharged with the way you're talking about fuel management... but I think some people here are assuming that you're stock.
What are your mods? What are your ACTUAL engine temperatures? What else do you know about this problem that you're having? Approach it logically and you'll find your solution.
Old 07-29-2009, 01:45 PM   #15
Biggie™
Biggie™'s Avatar
Originally Posted by Loren View Post
What are your mods?
Good question, I was just going off the information in your Yaris World garage. Is that current?
Old 07-29-2009, 05:52 PM   #16
thepoche
thepoche's Avatar
Drives: Toyota Yaris CE
I had the fuel cut off or ECU in limp mode thing happen to me on a track day. The car would not accelerate at all, either coast or slow down and then the check engine light came on. I pulled off the track and waited for the session to be over and everything was fine afterward.
I checked the Error codes after and had two new ones.
I don't remember the actual codes but the description was along the line of "Camshaft position sensor out of range" and another one for O2 sensor temperature.
I cleared them and they never came back. I never saw the Coolant temp light, so I assume the engine was not overheated.
I'm not sure what caused this but I know I was pushing the Yaris really hard trying to follow a WRX
thepoche is offline   Reply With Quote
Old 08-06-2009, 07:21 PM   #17
kurokoma-kun
Drives: 2007 Yaris HB
I got this the other week, when I was absolutely hammering it on a long uphill straightaway in 3rd gear and overboosted a bit (to about 9 psi) . At that point I got a flashing CEL and no acceleration that lasted as long as it flashed, maybe 15 sec. No codes though, no overheating, no other issues. So... this is a misfire, you think?
my yaris, kurokoma-kun
Last edited by kurokoma-kun; 08-06-2009 at 07:39 PM. Reason: cool, this was my post 1,234
Old 07-29-2009, 10:32 PM   #18
Tamago
Tamago's Avatar
Drives: UZJ100
sad that the yaris is so VW'y
Fuel Efficiency and the Yaris BailOut Fuel Economy Forum 327 01-02-2026 11:44 PM
Yaris Fuel Pump HTM Yaris General Yaris / Vitz Discussion 12 03-22-2012 03:34 AM
Last Fuel Bar andaconda Fuel Economy Forum 37 04-29-2009 02:35 PM
The Advantages of Nitrous on an Engine KCALB SIRAY Performance Modifications 7 01-02-2009 10:53 AM
Low fuel light falkor_99 General Yaris / Vitz Discussion 35 08-24-2007 03:20 PM
