![]() ![]() Drives: 2007 toyota yaris Join Date: Mar 2009
freeze frame - i swapped coils just to humor myself.
Okay, so if you guys remember me posting on here about mechanic telling me to bring car in saying that he needs to switch coil 1 with coil 4 and coil 4 with coil 1. well i did it last night. just for fun. heres what i came up with. the check engine light was on immediately. i then put back to normal (or how it was b4 i touched it) then i reset light. and so now i will wait again and see when light comes on again. this is fun.
Report#: 7 Report Date: 4-9-2009 (12:18 AM) Vehicle Year: 2007 Vehicle Make: Toyota Vehicle Model: YARIS Stored: P0354 Ignition Coil D Primary/Secondary Circuit Pending: P0304 Cylinder 4 Misfire Detected MIL ON MisFire Monitor Complete Fuel System Monitor Complete Comprehensive Component Monitor Complete Catalyst Monitor Not Complete Heated Catalyst Monitor Not Supported Evaporative System Monitor Not Complete Secondary Air System Monitor Not Supported A/C System Refrigerant Monitor Not Supported Oxygen Sensor Monitor Not Complete Oxygen Sensor Heater Monitor Complete EGR System Monitor Not Supported DTC for which Freeze Frame was Stored P0354 Fuel System 1 Status Open Loop Fuel System 2 Status Not Supported Calculated LOAD Value 41.18 % Engine Coolant Temp 123.80 °F Short Term Fuel Trim - Bank 1 0.00 % Long Term Fuel Trim - Bank 1 -4.69 % Engine RPM 1363 rpm Vehicle Speed Sensor 0.00 mph Ignition Timing Advance #1 Cylinder 8.50 ° Intake Air Temperature 71.60 °F Air Flow Rate Mass Air Flow Sensor 0.56 lb/min Absolute Throttle Position 19.22 % Time Since Engine Start 0 sec Bank 1 - Sensor 1 Equivalence Ratio 1.00 Bank 1 - Sensor 1 O2S Voltage 3.30 V Commanded Evaporative Purge 0.00 % # Warm-ups since DTC Cleared 0 Distance since DTC Cleared 1.86 mi Barometric Pressure 28.64 inHg Bank 1 - Sensor 1 Equivalence Ratio 1.00 Bank 1 - Sensor 1 O2S Current 0.00 mA Catalyst Temperature Bank 1 - Sensor 1 914.90 °F Catalyst Temperature Bank 1 - Sensor 2 661.46 °F Control Module Voltage 13.89 V Absolute Load Value 20.78 % Commanded Equivalence Ratio 0.87 Relative Throttle Position 0.00 % Absolute Throttle Position B 51.76 % Accelerator Pedal Position D 16.08 % Accelerator Pedal Position E 31.76 % Commanded Throttle Actuator 18.82 % Time since DTC Cleared 0 hr 19 min |
