Old 04-07-2009, 12:39 PM   #1
andaconda
andaconda's Avatar
Drives: '09 Yaris Sedan
back lit control?
First night out with the car I noticed that the pod that holds the mirror switch, and cluster dimmer control is not back lit, nor is the controls on the driver side door IE: the door locks, window locks or the other window switches (the auto down is lit.) The passenger door switches aren't back lit either. Is this just mine sedan or aren't any of the sedans back lit? I also noticed the the radio controls and three knobs that control heat and air are also a quite a bit dimmer than the speedo cluster. If you dim the speedo cluster to a comfortable level then you can't see the display on the radio very well. I have the square faced radio with the buttons down each side.
Any input?
andaconda is offline   Reply With Quote
Old 04-07-2009, 12:42 PM   #2
pixitha
Pixitha
I also noticed the issue with the radio back light being super dim, if i lower the HUD to a normal level....I found the HUD to be a bit too bright, but now the radio is a bit too dark!
2007 Yaris Sedan here
pixitha is offline   Reply With Quote
Old 04-07-2009, 01:02 PM   #3
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
the thing I don't understand about the sedans is when you 'click' the dimmer switch all the way up it turns off the lighting....all the other toyotas actually use that 'click' to lock the displays to max brightness
Xda Forums - Shroomster
Androidforums - Shroomster
I'm noticing a pattern......
Old 04-08-2009, 09:06 AM   #4
b_hickman11
Drives: 08 Sedan
The reason for this is because when you have to turn on your headlight due to rain or fog but its still day time, you will still be able to see you Speedo and gas gauge. If you didn't turn the knob all the way up to the clicked position during the day, it makes it very difficult to see your cluster.
BTW.....My Sedan has back lighting behind the lock/unlock buttons.....
Old 04-07-2009, 01:30 PM   #5
andaconda
andaconda's Avatar
So I'm going to take it that nobody has back lit controls...
To fix the radio being too dim, I suppose you could put a resistor in line with the HUD unit to dim it a bit further, and then turn the brightness up for the radio. It might take a little experimenting to get a good balance.
Old 04-08-2009, 12:20 AM   #6
wiirenet
wiirenet's Avatar
Drives: Black '09 2dr HB
Send a message via MSN to wiirenet
Yea the only stuff I have lit is the middle stuff, not the locks, window, & dimmer control.
But my old car didn't either so it didn't even occur to me to be bothered that its not lit.
wiirenet is offline   Reply With Quote
Old 04-08-2009, 10:05 AM   #7
andaconda
andaconda's Avatar
ya, the only thing that is lit on mine is 'auto down' window button...
Digital Gauges, Auto Climate control, Manu-matic shifter computerlove87 Cosmetic Modifications (Exterior/Interior) 21 12-03-2012 12:55 AM
Cruise Control - Again! CB900F2 DIY / Maintenance / Service 47 06-17-2010 07:29 PM
Back hurt? yarswiss Off-topic / Other Cars / Everything else Discussions 10 11-14-2008 05:39 PM
Rear wiper: EZ mod so it pulls back all the way joelitton Cosmetic Modifications (Exterior/Interior) 10 10-22-2008 11:30 AM
HELP!!! I went back to the service center yesterday for the 7th time in 2 months! Meldav86 General Yaris / Vitz Discussion 27 08-21-2007 10:04 PM
