toyota
help! im buying rims this saturday...
i need to know exactly if 205 will rub alot if the car is FULLY LOADED. got to get one this saturday wanna make the right choice. i am running trd springs but i guess thats beside the point.
rims im looking at is 16x7 205/50/16 +40offset. about .4 inch bigger in diameter and 195 is about .1 smaller diameter that stock or do i need to go for 195 instead of 205. i prefer 205 but depends on the rubbing issues.. anyone.
I ran 205/40R17s with TRD springs and it rubbed ALOT.
I now run 195/50R15s with coilovers (alot lower) and NEVER rub.
AEM CAI, NST Pulleys/SSK, WR 4-2-1 Header, TRD axelback, R1 Concept Rotors, TRD Sway Bar, Nitto Rear Strut Bar, Cusco GT-Zero Coilovers, 1ZZ-FE 1.8L TB |
With TRD's, the height of the two tyres mentioned will not create any rubbing issue. The problem (up front) is the wheel offset. With ET40, I would generally recommend 195mm rubber. If you go with JDM OEM 195/50/16, you should be good to go. However, if you're stuck on 205's, look for a higher offset wheel.
Go 195s marcus. Less weight and rolling resistance.
toyota
cool.. 195's it is..just hoping i can make the wheel gap smaller..*sigh*
if i go 205 what offset do i need.. would it be +45 and up. thanks guys!! |
toyota
ok so i guess +45 offset for any 205's will do.. it actually show this on wheel and tire guide i forgot we have that thread... thanks again.
toyota
new plan.. what offset can i have max on a 16X8 on the back without rubbing. i may go staggered instead. anyone.
so 16x7 front and 16x8 on rear what tires size though. |
are you running trd or toyota canada springs?
toyota
TRD..but it is besides the point..need to get a set up without rubbing when its fully loaded!!
toyota
anyone know what the max offset without rubbing and fully LOADED on the REAR of our hatchback with 16x7 and 16x8.. thanks!!!!!!!!!!
#12 | |
![]() Drives: yaris Join Date: Mar 2009
stick with your original 16x7 all around and 195/50/16 |
If you're trying to even things out front to rear, you can stagger offsets, which is a very common fitment on the Vitz in Japan, but rather difficult do accomplish in the States where most wheels are single offset offerings.
I run one set of wheels with staggered offsets: 16x7, 205/50/16, FR//RR ET45, ET37. Of course, you could always run spacers (10mm) in the rear if you insisit on a set-up that can be rotated. |
The last thing this car needs is anythingX8. 195-205 rubber on 16x7 is plenty wide and pretty much guaranteed safe as far as rubbing is concerned. If your objective for fat on the back is to bring the wheels out, then either play with off-set or go the Benggolf2 route and toss in some 10mm spacers (if you can find some).
Last edited by WeeYari; 04-02-2009 at 04:29 PM. Reason: kimona beat me to it!!!!!!1 |
toyota
thanks guys... i think ill stick with 16x7 +40 offset with 195/50/16... i can always run a spacer on the back ill do it after instead.
Rubber stamp it as 'Decision Made' before you change your mind again.
toyota
ok..
![]() Drives: 2005 Join Date: Mar 2009
i suggest u should stick to stock ones, u can use following tool to check ground clearence
http://rapidshare.com/files/218918392/TyreComp.zip.html |
| Who has a list of compatible Toyota rims for Yaris? | Yawesh | General Yaris / Vitz Discussion | 5 | 01-17-2009 10:29 PM |
| FS: 17'' Motegi MR7 Rims and Khumo Tires | Sabretooth | Items for Sale by private party | 11 | 07-02-2007 02:55 PM |
| Need help when ordering my tires and rims | thomasward00 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 4 | 04-26-2007 09:40 PM |
| FS: 07 yaris RS stock rims n tires | thegame11 | Items for Sale by private party | 5 | 04-15-2007 01:25 PM |
| hufeisen rims | JustYYaris | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 4 | 01-17-2007 03:16 PM |
