Old 04-08-2009, 02:07 PM   #1
train317
Train317
train317's Avatar
Drives: 2008 Toyota Yaris S Sedan
XXR Sportmax 513 Wheels and Tires
I'm convinced that I am going to buy the XXR 513s in gun metal gray for my 2008, silver sedan S. My sedan is lowered on Tanabe DF 210s. I would like to go up a rim size and put on 16 x 7s. My question is what would be the best offset for the rims and what size tire would help me avoid any problems with rubbing? Also, I am open to a tire brand/model. I live in Michigan and would be running this set up from spring through fall only. I use the car for commuting. Any help/suggestions would be much appreciated!
"Show me a person who has never made a mistake and I'll show you someone who has never achieved much"
train317 is offline   Reply With Quote
Old 04-08-2009, 02:46 PM   #2
Thirty-Nine
Small cars are a big deal
Thirty-Nine's Avatar
You'll want the highest offset you can get, basically. A +40 or +42 would be great.
Old 04-08-2009, 02:48 PM   #3
train317
Train317
train317's Avatar
OK..so 0 and 15 are out...I see that alot when this rim is advertised.
Old 04-08-2009, 03:15 PM   #4
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
+40 with 195/50/16 , +42 and up 205 will do without rubbing.. rear i believe you can get away with +30 offset on 205's.. but i could be wrong.
Old 04-08-2009, 03:35 PM   #5
Thej3sta2
Thej3sta2's Avatar
Drives: Soon to be LFA
those would look awesome on my Aw11
Thej3sta2 is offline   Reply With Quote
Old 04-09-2009, 10:19 AM   #6
train317
Train317
train317's Avatar
Ok.. so around +40 for the rims would be ideal?
Old 04-09-2009, 10:20 AM   #7
train317
Train317
train317's Avatar
195/50/16 woudl be good for tires? Would that be taller, same or shorter than stock do you know?
Old 04-09-2009, 12:08 PM   #8
marcus
toyota
marcus's Avatar
the same the stock rs, the stock is actually .1 inch bigger which is almost nothing..unless you got base model which uses smaller diameter wheels then this setup is a lot bigger.
Old 04-10-2009, 03:09 AM   #9
Benggolf2
Benggolf2's Avatar
I run a 17 x 7 +40 offset wheels with 205/40 x 17 tires on my Yaris 4-door LB. Car is also lowered with Eibach Pro-Kit springs. Absolutely no rubbing issues. Check photos in my garage.
Hope this helps. Good luck.
Benggolf2
Old 04-10-2009, 03:01 PM   #10
train317
Train317
train317's Avatar
Thanks for the info Marcus and Benggolf 2...wow your car looks very, very tastefully done. Thanks for all the info thus far. From my research it doesn't look like enough offset is offered on a 513....I did find a similar wheel...ROTA RB...it comes in either a 40 or 42 offset among others. Now I just need to find a place that sells them and wouldn't mind getting tires from the same. Would need it shipped to Michigan. Any ideas on where to buy. Most of the really big tire/wheel distributors don't seem to carry ROTAs....
Old 04-10-2009, 03:28 PM   #11
Benggolf2
Benggolf2's Avatar
Thanks for the compliment. For ROTA wheels, I suggest you contact Garage 5 at (604) 278-4339 and ask for Rob or Richard. Tell them Beng referred you. You can email them at rich@garagefive.net.
BTW train317, I have +10mm H&R wheel spacers at the rear to bring the tires almost flush to the body work (no rubbing whatsoever). You might want to consider doing the same.
Benggolf2
Old 04-10-2009, 03:49 PM   #12
33OH
Drives: '08 Yaris
Let me throw in that I run a 17x7 +42 offset wheel and I do rub (on DF210's), so I would go for the +40 offset that Benggolf2 uses and has no issues with.
Old 04-10-2009, 09:07 PM   #13
Benggolf2
Benggolf2's Avatar
What springs you use to lower your car makes a big difference too.
DF210 lower the car more than Pro-Kit springs. Ryank, you car looks lower than mine in the photos.
Benggolf2
Old 04-12-2009, 06:36 PM   #14
train317
Train317
train317's Avatar
Thanks for all the good info. BengGolf 2 did you have to go with longer wheel studs when you put on the rear spacers?
Old 04-12-2009, 09:35 PM   #15
Benggolf2
Benggolf2's Avatar
Yes, I ordered the H&R 10mm spacers from MicroImage and they came with longer wheel studs.
Benggolf2
Old 04-13-2009, 12:14 PM   #16
train317
Train317
train317's Avatar
Excellent thanks for the info!
Old 04-13-2009, 12:14 PM   #17
marcus
toyota
marcus's Avatar
thats kinna weird how you rub on +42 and not on +40 which sticks out more???
Old 04-13-2009, 01:41 PM   #18
kargoboy
kargoboy's Avatar
Drives: '07 Yaris Sedan/'03 Protege
I just wanna interject this: 195/50/16 are very limited in selection and price.
Go with 205/40 or 205/45, there are a lot more choices.
kargoboy is offline   Reply With Quote
Original (almost new) Yaris wheels / tires kennywhy Items for Sale by private party 3 08-28-2009 01:27 PM
OE wheels + tires question Tonavi Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 03-05-2009 11:35 PM
FS: Rays Wheels and Tires spechuy Items for Sale by private party 10 11-07-2008 10:37 AM
Keep tires on stock wheels? LtNoogie Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 10-31-2008 11:00 PM
Factory base wheels & tires for Liftback kennywhy Items for Sale by private party 6 01-22-2007 07:31 AM
