Dang our pcv systems sure do like to suck up oil!!!
Okay so i installed a oil catch can using the home made home depo filter.
After about 2 weeks i can already see a teaspoon of oil. I am figuring the way things are going the filter should be completely full by the time its due for another oil change. Cant belive how much oil is going into the intake. I cant imagine without this mod how much oil buildup residue is going to be coating the intake, valves etc. For the cheap cost and if you dont mind emptying the oil it catches every few months i would highly reccomend this for all members.
![]() ![]() ![]() ![]() ![]() ![]() Drives: '08 Bayou Blue LB AT Join Date: Oct 2008
That's why I have to install my catch can. That oil is coating the inside of my S/C and I'm not sure how to clean it.
aFe Intake | Blitz Supercharger | Megan Header | TRD Exhaust | NST Pulley Set TRD Shocks/Struts | Tanabe NF210 Springs | TRD Sway Bar | Motegi TRAKLITE wheels | Kuhmo Ecsta XS R1 Concepts slotted rotors | Carbotech 1521 brake pads | stainless steel brake lines | Seibon vented carbon fiber hood |
1 word SEAFOAM!!!
I'm too lazy to search while I'm at work. Where is the Seafoam introduced? In front of the throttle body?
Behind the throttle usually. You can even take the tube of the pcv valve and get a areosal version of seafoam and spray it down. Will clean all the oil and carbon buildup off your intake manifold as well as clean your valves and any carbon buildup in the motor.
Ok, I'll look into that this weekend. Thanks.
SIPNDEW
does the catch can go on the line that goes from valve cover to intake, or pcv valve to manifold?
pcv to manifold. Maybe ill install a second one to intake but i dont think that sucks hardly any oil at all.
SIPNDEW
ok, ive had a can i was going to use on another car but why not put it on the yaris.
best way is to let it suck in about half a can slowly. Then shut the car off and let it soak for a hour. Then run the other half to clean out the soften carbon and gunk. Then the car will smoke like something fierce.
![]() ![]() ![]() ![]() ![]() Drives: . Join Date: Apr 2007
where is the DIY for the catch can?
Steals terrorist's lunch
Drives: 2007 Yaris Liftback Join Date: Mar 2007
- Brian Share the Road I often carry 2 carpool passengers and mountain bikes or snowboards/skis over a 4,500 foot elevation difference. Click the graphic above to see my detailed mileage logs. |
kanye
in the diy, the husky filter, do they not make it anymore? i search google and cant find one.
but wtffffff, i went to walmart, 2 home depots, lowes, hectors hardware, 2 sears stores, and a sears hardware. NO ONE has this type of filter at all. other than online where should i go? |
![]() ![]() ![]() ![]() Drives: 08 3DR 5M Bayou Blue; 09 Fos Join Date: Oct 2008
I think the engine needs some top oil going on the valve stems at cyl top. Maybe you got too much oil in your engine. I only put 3.5-3.75 Qt and have zero oil usage.
In between cities
Drives: 2006 yaris ce Join Date: Feb 2006
hey kenkyd, home depot has it but by a differnet company. At home depot there in the air compressor section. Just take a photo of it, since they'll have no idea what your talking about with out it.
| DIY: CHANGE MANUAL TRANNY OIL | ttufrosty | DIY / Maintenance / Service | 157 | 09-07-2018 02:43 PM |
| DIY Oil Pressure Gauge Install | LtNoogie | DIY / Maintenance / Service | 13 | 11-20-2009 05:13 PM |
| Intake Systems Decision Maker.. | Blenjar | Performance Modifications | 25 | 09-15-2007 11:07 PM |
| Compiled 1NZFE Used Oil Analysis | craigq | DIY / Maintenance / Service | 7 | 09-10-2007 05:27 PM |
| Motor oil debate - interesting info but a long read. | mikeukrainetz | General Yaris / Vitz Discussion | 6 | 12-10-2006 09:16 PM |
