Old 05-20-2009, 01:21 AM   #1
javagirl
Drives: 2009 Yaris Black LB, Auto
New Owner - Lights on Gear Shift
I'm happy to see there is a forum for Yaris owners. I'm looking forward to learning more about my new car.
That said...I have a complaint. I've only been driving it for a couple of days. I did a search on lights on the gear shift in the forum here and found several threads about there being no lights on the gear shift positions. I park in a underground garage and can't see what gear I'm in when pulling in or out of my spot. I understand I can turn on my lights, but I'm just astounded that Toyota wouldn't put lights on the gear shift. I haven't been driving it long enough to know what gear is where and I don't find stumbling around in the dark for the right gear to be a safe or acceptable solution. Does anyone know if there is an aftermarket fix for this? Thank you.
javagirl is offline   Reply With Quote
Old 05-20-2009, 01:42 AM   #2
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
No fix is required. Give yourself a little time to learn the car, you'll instinctively know where the gears are instantly without needing to look or even think about it.
Seriously, it will be as natural as scratching your nose. You don't need a light on to do that, right?
Old 05-20-2009, 03:16 AM   #3
SilverBack
Joey
SilverBack's Avatar
Drives: '14 Scion xD 5-speed
Congrats on your new Yaris and welcome to YW!
I agree with Loren. It takes a little while to get used to the Yaris. It took me almost a month before I stopped getting weirded-out by the gauges in the center. See if you can find the cupholders lol.
By the way, what part of Pasadena you from?
Old 05-21-2009, 05:15 PM   #4
The little red pill
Taking care of Bubbles
Drives: 2009 Yaris LB "Bubbles"
My car which is a 2009 auto LB, shows me what gear I'm in on the dash above the odometer.
2009 Absolutely Red LB. "Bubbles"
The little red pill is offline   Reply With Quote
Old 05-21-2009, 06:13 PM   #5
HTM Yaris
resident senior
HTM Yaris's Avatar
Drives: 07 Yaris
Addendum to what Loren said , the 1st , 2nd , 5th and reverse gears are spring loaded when coming from the nuetral position . Go ahead , try it ( With car not running , clutch pedal depressed , and emergency brake engaged , just to be safe ) . From the nuetral position , move your shifter to the right as if you want to go to reverse ( don't pull the shifter down into reverse ) . Now let go of shifter . See how it returns to nuetral . If you pull your shifter straight down from nuetral , you will be in 4th gear . If you move your shifter straight up from nuetral you will be in 3rd gear . As Loren said , it will become second nature very quickly .
Old 05-22-2009, 02:44 AM   #6
AznGouki
Metsu
Drives: NCP91 ; E36
I wish it did that for the manuals as well. That part of the dash is so empty. Sometimes I need to be reminded that I'm already in 5th gear or I'm still rollin in 4th haha.
AznGouki is offline   Reply With Quote
Old 05-22-2009, 03:23 AM   #7
CtrlAltDefeat
I ♥ Yaris
CtrlAltDefeat's Avatar
lol I've had that before but usually I can tell by the sound of the engine when I'm in 4th on the highway, that and the fact that I end up passing people like constantly Most of the time now I'm used to it and can tell by feel what gear it's in (even with the short shift kit) Rather then the lights, I would prefer a tach!
Old 05-21-2009, 06:33 PM   #8
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
^^ She drives an auto.
Welcome javagirl!
Old 05-21-2009, 07:02 PM   #9
HTM Yaris
resident senior
HTM Yaris's Avatar
Drives: 07 Yaris
details , details
October sale on TWM Performance shift knobs! TWM Performance TWM Performance 1 10-31-2008 06:01 PM
Fog lights and shift knobs flip_yaris Cosmetic Modifications (Exterior/Interior) 3 10-20-2008 06:36 AM
2nd to 3rd gear shift (manual tranny) tekmoe General Yaris / Vitz Discussion 13 12-11-2006 07:27 PM
Shift knobs with lights? IsLNdbOi Cosmetic Modifications (Exterior/Interior) 0 09-20-2006 05:09 PM
Shift gear knob Jfoofoo Cosmetic Modifications (Exterior/Interior) 9 09-11-2006 01:20 PM
