![]() ![]() Drives: 2007 Toyota Yaris Sedan Join Date: Jun 2006
PVC valve routine?
You know I am at 95K miles, I've done the plugs, transmission fluid, coolant, and oil, belt, air filter religiously over the last almost 100,000 miles , but I haven't given much thought to other items that I used to swap out on my previous vehicle, like the PVC valve and the fuel filter. Now I know the fuel filter is located in the gas tank I believe its probably not something the faint of heart would tackle, but what about the PVC valve, should that have required my attention or is there anything else under the hood that is not a fluid that may be worth just peering at? I got the air filter and belt replaced already... I guess I have felt I have done my maintenance so well that I feel I am overlooking something. My car has been great to me... Ron
brakes? seems like you covered most of the wearable parts... the pcv valve can be cleaned with carb cleaner, or replaced for <$10
If you are referring to the PCV (positive crankcase ventilation) valve then its a cheap $10 pop out the old one put in the new one type of fix.
![]() ![]() ![]() ![]() ![]() Drives: . Join Date: Apr 2007
sorry to sound like a noob but where exactly is it located at?
#5 | |
Start another Oil Thread!
you nailed it sir.
nice... it never gets old
#7 | |
the fact that people never search before asking?
i agree
you nailed it sir.
Na your smart ass remarks are what get old.
god forbid someone ask a simple question that requires a simple answer. |
#9 | ||
what's the problem here?
you nailed it sir.
#11 | |
Drives: 2007 Yaris Hatchback Join Date: Oct 2008
#12 | ||
who's overreacting now lil man lol
you nailed it sir.
wow, no need for everyone to blow up. I thought his comment and link suggestion were plenty appropriate. If you DO use the search, you get alot more info that has already been covered.
you didnt mention brake fluid. if you havent done it already, change it. every 3 years or 30k should be good if you dont race the car.
| Valve Noise | barryware | DIY / Maintenance / Service | 25 | 02-13-2013 03:39 PM |
| anyone with p90x.....i need help with routine | severous01 | Off-topic / Other Cars / Everything else Discussions | 11 | 05-06-2009 08:29 AM |
| excessive valve and or engine noise? | thomasward00 | General Yaris / Vitz Discussion | 3 | 06-07-2007 01:34 PM |
| 2007 Yaris LB - Valve Adjustments | Pavel Olavich | DIY / Maintenance / Service | 3 | 03-30-2007 06:34 PM |
| PVC Intake | spkrman | Performance Modifications | 16 | 11-29-2006 06:19 AM |
