Old 03-31-2009, 06:48 PM   #1
captainm27
Drives: 2008 Sedan A/T Silver
Pee-U!!
So I turned the A/C on today, being months without use in the winter. Everything works out well, up until 10 minutes later, when the evil A/C stench decides to rear it's ugly stenchiness. Sheesh! What a treat I got for driving a nice spring day. I did the custom cabin air filter using BailOut's guide, thinking it might help. Alas, not even a strong NaturalAire home filter can withstand the might of the A/C stench.
captainm27 is offline   Reply With Quote
Old 03-31-2009, 06:57 PM   #2
mrbond
mrbond's Avatar
Yeah, I have the same problem, and I also tried replacing the cabin air filter. I think it might be mold growing in the cabin air box, but I don't know for sure.
- A Toyota Yaris
- A whut Yaris?
Old 03-31-2009, 07:21 PM   #3
YarisSedan
Drives: 08 Yaris Sedan
Quick and easy and cheap way to fix your problem.
Step 1 Let your car warm up to full operating temperature. Then roll down your windows and turn your heater on max hot for about 10 minutes full blast. Make sure its set to outside air. Once done go ahead and turn the heat down.
Step 2 Purchase a bottle of febreeze anti microbial spray. Spray as much as you can handle in the vent area which is located near the wiper blades. With the blower motor on it will suck down the febreeze through the vent system killing any remaining bacteria growing inside you ac duct system. Also giving you a nice fresh smell inside when you turn it on now =)
Step 3 enjoy your now nicely smelling car.
Explination: The high temperature heat kills most of the bacteria in the lower vent areas whiping out the nasty smell. The febreeze ani microbial does just like it says killing the upper bacteria of the vents while helping instantly removing odors.
Old 03-31-2009, 10:35 PM   #4
tetzyamis
'09 5dr
tetzyamis's Avatar
Drives: 2009 Yaris 5-Door Bayou Blue
Great idea!!!
Sounds like a good thing to do once in a while even if I use AC almost daily.
2009 5-Door Yaris LB Bayou Blue Pearl
2009 5-Door Yaris LB Black Sand Pearl
tetzyamis is offline   Reply With Quote
Old 03-31-2009, 09:10 PM   #5
b_hickman11
Drives: 08 Sedan
poor some bleach in the vents on the outside of the car at the bottom of the windshield where the wiper blades arms attach to the car.
Old 04-01-2009, 10:51 AM   #6
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
Bleach is about the most corrosive substance there is for steel.
Old 04-24-2009, 12:46 PM   #7
b_hickman11
Drives: 08 Sedan
You dont leave it in there. Poor it in...give it a few minutes to eat at the mold...then wash it out with a water hose.
Old 04-25-2009, 10:03 PM   #8
GeneW
Drives: 2008 Yaris
If you knew what bleach does to steel you'd never pour it into or near your car. I've seen bleach rust some kinds of stainless steel, as in crusty rusted stainless. Never would have believed it if I hadn't seen it myself.
Bleach is absolute murder on carbon steel.
A more gentle cleanser, one that doesn't attack metal may be in order. Don't know of one offhand.
Gene
Old 04-26-2009, 07:36 PM   #9
SilverBack
Joey
SilverBack's Avatar
Drives: '14 Scion xD 5-speed
It also helps to turn-off the A/C but leave the fan on a few minutes before you turn off your car. This dries up the moisture in the ducts and vents to help prevent any mold from growing. Most of (if not all) the smell should be gone the next time you start your car
Old 04-27-2009, 07:09 PM   #10
haku
haku's Avatar
Drives: sentra
Send a message via AIM to haku
yup, this is how to do it... dunno what's with all these crazy suggestions... alternatively, you can just run the a/c without the engine on. it has the same effect.
haku is offline   Reply With Quote
Old 04-26-2009, 11:21 PM   #11
b_hickman11
Drives: 08 Sedan
Gene
Use non-chlorine bleach then....
Old 03-31-2009, 09:19 PM   #12
toast
Drives: 2007 LB
I'm a newish 2007 Yaris LB owner, but your description sounds like a plugged condensate drain. My old ranger's a/c would start smelling like cat urine a couple of times a year. The fix was to ream out the drain with a coat hanger wire and a flood of water would splash out. My problem was spiders and dirt would accumulate in the drain tube and slow the condensate enough that bacteria built up.
toast is offline   Reply With Quote
Old 03-31-2009, 10:11 PM   #13
captainm27
Sounds like a good idea! I'm going to try that for sure! So the vents by the windshield is where the outside air comes in from? I didn't know that. What a noob!
i dipped my filter in lysol and then sprayed in all the vents, smells quite nice now
I was also thinking about something like that with the filter, but I didin't think about dipping it in something. The lysol doesn't damage or reduce the quality of the filter in any way?
Old 03-31-2009, 10:55 PM   #14
YarisSedan
Cost about 6 bucks and will last you years to come. And comes in many pleasant scents.
BTW they make a auto version for auto interior and fabrics. Used some on my acura thats been parked outside for months never driven. It smelled like...... well a old car that has never been driven. Now it smells like a new car =).
Old 04-01-2009, 10:56 AM   #15
and'll probably, well, bleach the plastics too??
Old 04-01-2009, 10:57 AM   #16
mrbond
mrbond's Avatar
Wow, the febreeze method works wonderfully. Omg.
- A Toyota Yaris
- A whut Yaris?
Old 04-01-2009, 11:41 AM   #17
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
wait a bit..i did an a/c spray it worked out as well but stench came back after a week..
Old 04-01-2009, 06:36 PM   #18
captainm27
Really?
