Old 06-01-2009, 10:13 PM   #1
Thedunpeal
Drives: Yaris LB
Send a message via AIM to Thedunpeal
Not starting. Help!
My 2007 yairs latchback is not starting up. Every time i turn the key is hear this horrendous rapid-clicking/grinding, what is going on?
The sooner the help the better
Thedunpeal is offline   Reply With Quote
Old 06-01-2009, 10:26 PM   #2
OK Yaris
Drives: 2007 Liftback
Sounds like your battery is dead. Have you tried jump-starting or charging the battery?
OK Yaris is offline   Reply With Quote
Old 06-01-2009, 10:49 PM   #3
Thedunpeal
Drives: Yaris LB
Haven't tried.. I have no idea where to have began. I tapped on the starter to see if that was the issue, tried unplugging and plugging the battery back in. Lights and music come on though. Could that still be the issue?
Thank you for the rapid response
Old 06-01-2009, 10:53 PM   #4
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
Yes , turn of radio and electric fan's , and try useing jumper cable's .
Old 06-01-2009, 10:53 PM   #5
OK Yaris
The battery is the most likely cause with your symptoms. Do the lights dim when you try to start it? Would you happen to have a voltmeter to measure the battery voltage?
If you know someone with jumper cables, that would be my first suggestion.
Old 06-01-2009, 10:55 PM   #6
Thedunpeal
Drives: Yaris LB
Alright, thank you folks.
If you lived close to me I'd love to fix any computer issues you have.
I'll keep an update.
Old 06-01-2009, 11:22 PM   #7
Thedunpeal
Drives: Yaris LB
Until help arrives to diagnose the issue, yes the lights are dimming when starting, no voltmeter. If it was the starter, god forbid, would the "Check Engine" light come on?
Old 06-01-2009, 11:32 PM   #8
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
It's a weak battery. If you have a friend with jumper cables, get it started and drive down to your friendly local car parts store. They'll swap the battery for you.
Old 06-01-2009, 11:40 PM   #9
Malaya1221
super duper M*******TOR
Malaya1221's Avatar
if it's manual and no jumper cable...u could ask ur friend for help to push start the car...
Old 06-02-2009, 01:16 AM   #10
Sir A.Y. Atoyot
Sir A.Y. Atoyot's Avatar
Drives: '08 5-door
Could even be dirty cable ends. Try taking them off and giving them a good cleaning. You'll have to do this in any case, so it's not wasted effort.
Sir A.Y. Atoyot is offline   Reply With Quote
Old 06-02-2009, 02:58 AM   #11
Thedunpeal
Drives: Yaris LB
Car runs. Had to change the battery. Thank you so kindly yaris forumers.
I ended up buying a battery that was a weee too tall for the bay, i had to take out the plastic holder from the bottom in order for it to fit... Hope i won't be needing that
Old 06-02-2009, 04:32 AM   #12
highwaypass
Captain Slow
Drives: '08 1.5 hatchback
it just a battery holder,but make sure that your new battery sat still in it's place.
There's only 1 brand,2 drive,3 words,4 you: TO-YO-TA
highwaypass is offline   Reply With Quote
Problems starting the engine fmicle General Yaris / Vitz Discussion 10 10-07-2009 08:48 AM
Starting Problems oconna2 General Yaris / Vitz Discussion 16 12-10-2008 04:39 PM
Fill up with Super before starting your boost project LtNoogie Forced Induction Forum 5 12-01-2008 06:41 PM
Starting Engine - Yaris Hatchback M/T gbuks General Yaris / Vitz Discussion 2 11-06-2008 12:24 PM
hard starting after moving car gonzo452001 DIY / Maintenance / Service 12 06-09-2007 05:07 PM
