Old 06-23-2009, 10:54 AM   #1
lilredrocket
Slowy getting there
lilredrocket's Avatar
Drives: 08 Liftback
Front Camber Bolts
Hi, I was wonder what degree of adjustment everyone was getting out of there camber bolts. I got -2.8 with mine and talked to another local member and he only got -1.4 with his. I got mine through work (goodyear ordered through a warehouse) and he got his through garm. I got to do my own alignment the other member had to pay extra because he asked for a (custom) alignment. Any thoughts?
Old 06-23-2009, 10:57 AM   #2
Tamago
Tamago's Avatar
Drives: UZJ100
i've seen -2 from a set of bolts. are you on 14mm or 15mm camber bolts?
"how" you do your alignment affects how much you can get out of a set of bolts. most techs simply turn the bolt in place. if you rest the weight of the car ON the front wheels, remove the locking pins on the bearing plates on the rack and allow the front to "sag" you'll get a LOT more than simply turning the bolt head.
we have a local autocrosser who actually straps the top of his tires and pulls them inward to get as much camber as possible wiht stock bolts (he was in a stock class). there really is a lot of play in most stock bushings.
Old 06-23-2009, 11:57 AM   #3
kngrsll
Apexing Egg!!
kngrsll's Avatar
cool trick
HighTach Motorsports
2007 Toyota Yaris-ARGH!!
Old 06-23-2009, 11:28 AM   #4
lilredrocket
Slowy getting there
Drives: 08 Liftback
Yea the car was sitting on the plates unpinned and I turned the bolt to get the -2.8 and the are 15 mm bolt to.
Adjustable Camber Bolts cali yaris Micro Image 30 12-11-2009 09:38 AM
Front camber bolt & Rubber bushings.. harveyjai Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 03-28-2009 06:34 PM
adjustable camber bolts.... xxae07xx Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 03-14-2009 04:33 PM
Are camber bolts needed after installing springs? CtrlAltDefeat Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 02-01-2009 12:19 AM
Who makes camber bolts? largeorangefont Wheels, Tires and Suspension Forum sponsored by The Tire Rack 21 07-08-2007 12:22 AM
